How many cold cranking amps does my battery need?
I also always buy the biggest battery that will fit in my vehicles. It's cheap insurance in my book especially in the winter months on a cold day/evening and also with all of the electronics, etc that run in todays vehicles. Also easier on the alternator when it needs to replenish the battery from the start up draw. In this case bigger is better naturally it may also depend on your funds. Just my $ .02.
I currently work for a major battery company, and we sell a LOT of automotive batteries.
Use the biggest one you can fit in there. It won't damage anything in your electrical system. My '85 has a 1,000 CCA Marine Deep Cycle Starting battery in it, and my '89 has a 750 CCA automotive battery. Driving and starting, I can't honestly tell a difference most days, but I like the added insurance of having more power if I need it.
The rated CCA for a typical Ford truck with a V-8 is around 650, but that's an average. I recommend going with as large as will physically fit in your vehicle.
When it comes to cranking power in a battery, there's no such thing as "too much", only "not enough".
Thanks
Itch
I use the marine starting deep cycle, because I run lights and an inverter off my truck a lot when I'm out and about, and a normal car battery will not take the constant power drain I place on my battery.
Deep cycle batteries can stand being run all the way down to dead and charged back up. Do this once or twice with a regular car battery and it will severely weaken (if not completely kill) the battery.
There are different deep cycles, in case you were thinking of trying this. I'll give a brief description of each.
Automotive Standard Battery:
Typical applications for starting, lighting, and ignition. These will work well for most people, as they usually just run a battery for the car's starting sequence, and occasionally playing the radio for a few minutes. Good only for large bursts of energy to run the starter (and any accessories that are on when you turn your key).
Advantages = Typically moderate cost.
Disadvantages = Can be damaged by constant drain/recharging. Needs to stay full (or close to full) at all times.
Marine Deep Cycle:
Normal battery found on boats that typically only use the battery to run lights and accessories. Good for moderate drain for long periods of time. Not good for starting applications.
Advantages = Constant power drain, able to run all the way down before charging.
Disadvantages = low burst power capabilities, moderate to high cost.
Marine Starting Deep Cycle:
Used for larger boats with electric starters. Powers both the starting sequence of the boat's engines, but also the lights and accessories. Basically a "best of both worlds" kind of battery.
Advantages = Starting power is high, can run all the way down and charge back up without damage, good for a "just in case the alternator fails, I don't have to buy a new alternator AND battery".
Disadvantages = Cost is fairly high, battery is large and heavy. Will fit some pickup applications without modifications, but make sure of hood clearance to the top of the terminals.
Basically, if you don't plan on doing anything that drains your battery while the vehicle is off, you don't really need a deep cycle. If you're like me and run lights and such from your truck while it's off (especially for long periods of time) you would do well with one.
Marine Deep Cycle:
on
1 Post
Well Itch i live in canada a few provinces over in Saskatchewan it gets real cold here somedays like -30 -40 easily but usually never gets to -40 but for my F150 with a 351W i have 625 cold crankin amps and it seeems plenty many recommend for 5W30 in the winter and 10W30 in the summer
Im runnin 5W30 synthetic its lighter so easier on startin the truck too
HuntM
11-30-2010 08:45 PM
Itch71
09-28-2007 08:29 AM
