2004 Ford Freestar concerns - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 11-16-2007, 06:37 AM
Gregs69GTO Gregs69GTO is offline
Gregs69GTO is starting off with a positive reputation.
Hey y'all.
I purchased an 04 Freestar in February of 07. It's been a good van and I like it alot, but it has been doing some things lately that have me a bit worried. I am hoping someone can either confirm or dispell my concerns.
First, The transmission. While the past week or so has been ok, there for about a month, when I would leave in the morning or after work with the van and it was cold outside, the 1-2 shift would be very harsh. It would almost bang the 1-2. It has since stopped doing that, so I don't know what the issues was, but it concerned me.
Second, Everytime I start the van when it's cold there seems to be bottom end bearing noise for about a second or so. After that it's gone and it does not do it after it's warmed up. I am running castrol synthetic blend 5-20W and either purolator or motorcraft oil filters. The bearing noise concerns me as I know it should not be doing that.
I don't think the dealer would do anything about it do y'all? The van has 48K on it and it was certified ford pre-owned so it has the 6yr-75K extended warrenty on the powertrain.
Any suggestions or comments would be welcome. I am a former professional wrench and I do all of my own maintenance and I am very **** about it, so this has me a bit worked up.
Thanks in advance!
Old 11-19-2007, 02:36 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman NewEnglandHerdsman is offline
Moderatee...
NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.NewEnglandHerdsman has a spectacular reputation.
I would suggest taking it to the dealer, explaining the problems and asking them to address them. They probably won't do anything, but that least makes the dealer aware of the issues and puts you on the record as having some potential issues...
Old 11-19-2007, 04:23 PM
osbornk osbornk is offline
osbornk is gaining momentum as a positive member of FTE.osbornk is gaining momentum as a positive member of FTE.
The transmission is the weak point on Ford's vans. if you have not done so, you should have the fluid and filter changed in the transmission. The noise you are hearing may be piston slap. It is common on many vehicles and normally does not do any harm.
Old 11-20-2007, 07:45 AM
Thanks for the responses gents. I just may take it in and let them look at it. The trans has not been banging on the 1-2 for the past month or so and when I purchased the van I asked them to service the trans for me (38K when purchased), because I know how important that is.
This is not piston slap, or at least I do not believe it is. The engine does build oil pressure very quickly though, the oil pressure light goes out as soon as the engine fires or perhaps a second or so afterwards. My F250 does have the piston slap issue so I am familiar with that sound. It almost sounds like a diesel until it gets some heat in the engine....LOL. It does run strong though.
Thanks for the help.
PS, I thought Ford got their minivan transmission issues squared away when the Freestar was released right???????? LOL, I hope so, I know the Windstar transmissions were junk.
Thanks again!
Old 11-20-2007, 05:28 PM
Bruker's Avatar
Bruker Bruker is offline
Bruker has a very good reputation on FTE.Bruker has a very good reputation on FTE.Bruker has a very good reputation on FTE.
Quote:
Tell me about it. I only got 170,000 miles out of my `01 Windstar transmission before it gave out.
Old 11-21-2007, 07:44 AM
Quote:
Well, then you took good care of it, serviced it properly and got lucky as well. That is good service out of an automatic.
Thanks for the reply.
Old 12-10-2007, 02:17 AM
gafft1 gafft1 is offline
gafft1 is starting off with a positive reputation.
2004 ford freestar 70000 milesmisfire
had a misfire in cylinder 3 so i changed the plugs and the wires but now it runs worse. it won't hardly run and it eventualy dies. i changed the wires and plugs one at a time so i don't think i got them mixed around. does anyone have the order that these are suppose to go in so i can double check i have them in the right place. What else could be causing this.
thanks
Old 12-10-2007, 09:18 PM
ranger1999 Bob's Avatar
ranger1999 Bob ranger1999 Bob is offline
ranger1999 Bob has a good reputation on FTE.ranger1999 Bob has a good reputation on FTE.ranger1999 Bob has a good reputation on FTE.
after having fram and purolator filters jamming on me i swear by the motorcraft filters on my ford.I will not use anything else
The dealer will prolly tell you they cannot duplicate the problem and tell you not to worry about it
Old 12-10-2007, 10:07 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
gafft1 on the coil pack the plug wires aren't in order on both sides. On the back side you have 1,2,3 and on the front they are 5,6,4.
Any chance you knocked off a vacuum hose or something?
Old 12-12-2007, 01:29 AM
misfire
I had two wires on the front turned around so i switched them back although it is running a bit better i am still getting a misfire on cylinder 3. Brand new plug(put in by dealer) and brand new wire what else could this be? Would the ignition coil or distributor cause a misfire on one cylinder these parts are both around $100 each and aren't the easiest things to get to. Is there something else i could try.
Old 01-15-2008, 07:09 PM
jmwhips jmwhips is offline
jmwhips is starting off with a positive reputation.
freestar misfire
Were you able to fix the problem and what was it? We have the same problem with the same van and cylinder. We'd appreciate any help you can give us. Thanks
Old 01-16-2008, 01:29 AM
Yes I had the dealer fix this it was the ignition coil which is very hard to get to without tearing your van apart.
2005 Freestar Question??? tcr1016 Aerostar 11 06-14-2016 05:13 PM
1977 lifted 4x4 conversion econoline cyborger 1968-2013 Full Size Vans 4 02-26-2015 10:49 AM
Need help, 2004 Ford Freestar, passenger side power window does not work. Gregs69GTO General Automotive Discussion 0 05-15-2008 07:11 AM
NEED HELP, Vehicle down, 2004 Ford Freestar, CV Joint Boot Replacement Gregs69GTO General Automotive Discussion 3 03-15-2008 08:58 AM
05 Freestar Van with 4.2 Wrenchtraveller 3.8 & 4.2L V6 5 04-10-2006 10:55 PM
Tags
2004, coil, cold, engine, ford, freestar, hard, ignition, misfire, misfires, multiple, pack, photo, shifts, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
