going down road at 75mph truck just died and will not start changed cps still wont start last dtc codes po344 po340 p1aee pooo8 po8a6 poo27 p1011 if have any info. please let me know asap thnks jtm
P0344 CMP Sensor Circuit Intermittent
P0340 CMP Sensor Circuit Malfunction
I don't have the other codes listed in my service manual, but I'm starting to see a pattern here. Where did you get your CPS? I've heard of ones from the auto parts stores going bad as soon as there put in.
had had a spare cps and then ckecked it again through a friends truck and it worked fine still down any help would be appreciatded thanks jtm
Check the wiring to the cps. I had a similar problem that ended up being bare wires at the cps plug. Also, make sure the connection is clean and use some dielectric grease.
same problem with my 2002 f-250 diesel. dtc codes p0008, p1aee, and p08a6. any luck with your truck? i have changed throttle position sensor, cleared problem for abuot 3 weeks then problem reappeared. any help or other info greatly appreciated.
