Headlight problem
i would check the fuses, i believe there are fuses for each of the high and low beams. it should be in the fuse box under the hood (at least it was on my 2000)
then if the fuses are fine. when you replaced the bulb did you look at the socket? if you see alot of white powder on the terminals then the socket needs to be replaced.
go to autozone and pick up a headlight bulb socket ($4.95) if it looks like it is bad.
