Supercharger on a 300-6 - Ford Truck Enthusiasts Forums
Old 04-27-2002, 11:44 PM
wildjon300ci wildjon300ci is offline
wildjon300ci is starting off with a positive reputation.
I'm looking and doing some preliminary research on adding a blower to my 6. At the moment, I need some info on what I need to supercharge it. About how much boost can I run without having to run over 93 octane? I have had no internal work done to the motor besides the cam at the moment. Would about 325+hp and 400+ftlbs or torque be feasable. What all do I need to do to prep my engine? How would I tun the carb?
Thanks a million.........Now I wonder what the look on a Trans Am drivers face would look like when I walked him...:-staun
Just tossing around ideas at the moment
Old 04-28-2002, 11:21 AM
ladewigm's Avatar
ladewigm ladewigm is offline
ladewigm is starting off with a positive reputation.
Great idea, sounds very intresting! Just wondering what gearbox you are using? Would love to Super Charge mine but definately not with a 3 speed coloum shift!!
Old 04-28-2002, 11:28 AM
I have C-6......Planning to use a GV ovderdrive unit when all is said and done.
Old 04-28-2002, 04:34 PM
ExplicitHP ExplicitHP is offline
ExplicitHP is starting off with a positive reputation.
The question is not how much boost you can run, but where the hell did you find a supercharger for this engine. I've never seen one, but would love to have one. Are you planning on machining your own supercharger intake? If you found a company that sells one please share
-Jon
Old 04-28-2002, 08:06 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
I would LOVE to put one on my 95 too.
Primary rig is:
95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds
NEW PICS IN MY GALLERY!! :-)
Then theres:
88' F-250 Superduty 351 + c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 and a
3 spd column shifter. Top speed, 65mph, Go Baby Go!
The newest addition to the Ford family is a 99' Mustang GT 4.6L
Old 04-28-2002, 09:59 PM
Right now the plan is to take a Eaton M-90 off a turbo coupe and mount it under the Ac and then plumb it like a blow-through turbo....mmmmmmmmmmm POWER
Old 04-29-2002, 01:19 AM
charlez's Avatar
charlez charlez is offline
charlez is starting off with a positive reputation.
I think you mean a M-90 off a SuperCoupe. (Turbo Coupes had Turbos)
http://www.eaton.com/graphics/supercharger/M90/super.gif
Old 04-29-2002, 08:17 AM
Sounds cool, obviously an upgraded ignition will be needed, MSD 6A? Will the computer automatically compensate for the increased air density?
-Jon
Old 04-29-2002, 01:07 PM
DoubleA DoubleA is offline
DoubleA is starting off with a positive reputation.
I was doing research to turbo or supercharge a car I have.
You are better off using draw thru on a supercharger.
you could mount the charger on the drivers side and plumb it over.
you wouldn't have to do any radical changes to your carb.
to pressurize a carb, there needs to be alot of internal changes.
if you draw through, your vacuum system would stay the same.
you'll need the MSD6A with boost timing retard and a bypass valve.
You may want to double check but I thought the supercoupe came with the eaton M62.
They are always on ebay
Old 04-29-2002, 01:27 PM
Ok, i see you a working on this for a carbed engine, you have me intrigued though, i think i will find a supercharger to hook up to my fuel injected I6.
-Jon
Old 04-29-2002, 04:42 PM
>You may want to double check but I thought the supercoupe came with >the eaton M62.
>94 F150, was 2x4, I6.
>Now 4x4, 302, 8 bolt, 4" suspension, 3" body, 36's
I was at school today and I realized about the vaccume wouldn't be right with a blow through supercharger setup. There wouldn't be any...so that means heater/ac controls and the computer wouldn't know how much to advance the timing. How would I use a draw throught...maybe fab up a plate and tubing that bolts to the carb plate and then under the supercharger?
Thanks
Old 04-30-2002, 08:39 AM
Yesterday on my reply I was wrong. The GM uses a M62 and Ford uses a M90. OOPS!
Anyway, check out this ebay auction for a T-bird charger: http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&item=1825309499&r=0&t=0
it has an adapter that goes to a round flange that could be piped to your intake. or use the intercooler too and then pipe over. you'd need some kind of adapter to go off the rear of the charger to your carb.
there's always those chargers on ebay. I've been looking for a while now.
keep posted on what you do. there's a lot of people that would like to do that.
Aaron
Old 05-01-2002, 01:46 PM
Custom Junk Custom Junk is offline
Custom Junk is starting off with a positive reputation.
I had a TO-3 turbo on my 250 I-6 maverick. It was a draw thru set up with a 500 cfm Holley mounted ahead of it. Ran real good. Have pics at www.bigal.cz28.com Look on photo page. ANy questions just ask me. I can lead you thru a turbo setup for a six
Old 05-01-2002, 05:09 PM
stractor stractor is offline
stractor is starting off with a positive reputation.
OK, this is going to tell you how old I am. The perfect supercharger for the 300 would be the McCulloch/Paxton VS57 or a VR57. You can hang one of these babys anywhere and it is belt driven off of the crank pulley or rather a added on pulley on the crank nose. You cruse with 5 pounds of boost and when you stomp on it the drive pulley on the blower changes ratios thus the VR or VS (variable ratio the other is variable speed )in the number( through a kick down switch or even better a toggle switch )and you get 7-9 pounds of boost.Won't melt your pistons with 8 pounds. They were originally blow through in the OEM applications as the carbs were pressureized, this is not as hard as it seems. All you have to do is put the carb in a box so it is subjected to the same pressure inside and out and with todays cable throttle linkage it should be really easy.We used to seal up all the holes to the outside of the carb and blow through the intake of the carb. I had one on a 53 olds engine in my 48 Ford 5 window coupe, using a pressurized 4cg rochester 4 bbl and mallory dist with no vac advance. Now you are probably asking where can you find one of these??? Well find a 1954 Kaiser Manhattan, 1957 Studebaker golden Hawk , T-Bird or Ebay http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&item=1825311593&r=0&t=0
or search ebay for McCulloch supercharger.
They are avaliable new but look much different and cost much more that the $25 I paid for the two I had.
stractor
Old 05-01-2002, 05:17 PM
Going back to what was said a few posts back, what about vacuum? If the entire intake manifold is under 5 PSI boost, where do you get vacuum from? Or could you have a vacuum can with a 1 way check valve to maintain vacuum when you are running under boost?
-Jon
idea for an efi 300 six cyl supercharger.. 70torino429 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 11 07-13-2015 07:35 PM
1995 f150 300 i6 turbo or supercharger? orderthesun 1987 - 1996 F150 & Larger F-Series Trucks 16 10-30-2012 10:47 PM
Supercharging 72' 6.4L bikerboyz80817 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 4 03-21-2012 10:13 PM
idea for an efi 300 six supercharger.. 70torino429 Ford Inline Six, 200, 250, 4.9L / 300 36 10-11-2010 10:22 PM
Supercharger for a 300-6? nelgin Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 4 12-14-2004 09:25 PM
Tags
200, 300, 300m, blower, carb, ford, i6, inline, paxton, sbf, supercharge, supercharged, supercharger, surpercharger, vr57
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
