Tranny I.D. ????????
Hi, just found out thru changing tranny filter that my C4 is not from 1965. judging by filter it is from 1970-78 vehicle. Trying to get correct modulator valve...didn't shift twice. (3 speed) Now wondering about yr. of engine- 289, & tranny, definitely a C4, 6 bolt to engine, 1965+ hard time reading the numbers. faint. Got engine/tranny from junkyard, out of a 1965 Ford Galaxie 500. Time to get accurate info on engine/tranny. Never assume! any help will be appreciated.
1951 f1
1951 f1
Originally Posted by chilione99
Hi, just found out thru changing tranny filter that my C4 is not from 1965. judging by filter it is from 1970-78 vehicle. Trying to get correct modulator valve...didn't shift twice. (3 speed) Now wondering about yr. of engine- 289, & tranny, definitely a C4, 6 bolt to engine, 1965+ hard time reading the numbers. faint. Got engine/tranny from junkyard, out of a 1965 Ford Galaxie 500. Time to get accurate info on engine/tranny. Never assume! any help will be appreciated. 1951 f1
1965 Galaxie 289 came with either a C4 OR an FX Cruise-O-Matic (aka small cruise-o). The pan gasket of an FX looks very similar to a C4 pan gasket. How many bolt holes in the C4 pan?
C4 trans filters: one type used from 1964/69 (Motorcraft FT-36-A), another from 1970 thru 1979 (Motorcraft FT-40-A). There are two more. One was used in 1970/77 Bronco's (Motorcraft FT-49), the other in 1973/80 Pinto's and 1974/78 Mustang II's (Motorcraft FT-42). C4 pan-11 holes.
FX trans filter: Motorcraft FT-31-A / FX pan gasket = B5AZ-7A191-B 14 holes.
may not be 65 engine, tag is missing on tranny. 11 bolt pan went to change filter and fluid...old filter has a tab to the side , holds in a ball bearing?and spring. found out when I tried to install the new filter(which I bought for a 65. thinking that was what it was) spring and ball fell into fluid pan. pics online show that would be a 70-78 c4 some days are better than others.
289 = 1963/68 / 302 = 1968 and later.
Engine ID: Look for a stamped number on the vibration damper. 289's used 3 types, 302 used at least 5 = 1968/79.
Thanks again. time to roll up my sleeves and get some info. maybe you would help id the engine from the damper number? My luck at matching up numbers is non existent. headed down to truck now. the rain won't melt me.
Mebbe I should call my Aunt in Sandwich, and ask her what rain looks like.
