oil pump shaft question
Im putting my 460 back together - after being apart for a few months...I forgot which way the oil pump shaft goes in
Im thinking the little "umbrella" on the shaft keeps it from falling thru when the engine is on an engine stand and upside down and keeps it from being pulled out with the distributer when right side up
so - am I correct that the "umbrella" goes toward the distributer - NOT the oil pump?
I feel stupid asking - but I SURE dont want to make a mistake and have to tear into it to fix -
also what direction do I turn the shaft to prime the engine before initial start up??? clockwise or ccw ?
thanks -
thanks -
There have been lots of posts where guys have put the shaft in with the umbrella up. It will then follow the distributer out and then fall back into the sump. Major headache.
When done properly it's trapped in position between the pump and the block and can't get lost.
Turn the shaft CCW as viewed from above to prime your oil system. Tape a 5/16 socket to an extension to be sure you don't lose it in the sump.
bsaastad
15
04-18-2016 07:38 AM
annaleigh
04-23-2015 03:14 PM
mmuenchow
05-14-2011 05:32 PM
supercab78
04-19-2002 01:03 PM
