You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Ok so i think i might have messed up my flatty. I put to much oil in and it started to run real bad.... When i had no choke on the thing would rev up so high untill i turned the key off. Whats the deal? I drained all the oil (way to much was in) and but the 5 qts that the manual said to. and it still does it. Could it be a blown ring?
Please help.
Alec
__________________
Alec Goldsmith
-1995 F-250 PSD, Extended cab, long bed, Dana 60 swap, 6637, 10k,
-1949 F-3
Member Massachusetts Chapter
Well it was that little tap under the carb that is connected to the fuel accelerator pump... it came off the attachment to the lower butterfly valve and pined it all the way open.... OOOPS
I sure learned my lesson,
Alec
__________________
Alec Goldsmith
-1949 F-3
