Steering wheel vibration at highway speeds
I have noticed since the day I drove my truck off the lot i have a very slight steering wheel vibration at highway speed. 60-70mph. It does NOT do it all the time, it is more pronounced on rougher highways, but sometimes it is smooth as glass. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I have the factory 20" wheels and Pirelli Scorpion ATRs.<o></o>
<o></o>
I was thinking the tires need to be rebalanced.<o></o>
<o></o>
Hopefully this is not a common problem, any input is appreciated.<o></o>
<o></o>
Thanks!<o></o>
<o></o>
<o></o>
<o></o>
Thanks!<o></o>
go have them balanced its an easy thing to do. thats the first thing any shop will do.
http://media.putfile.com/feast
Same problem
I recently just bought a F150 King Ranch 2007 and I noticed the vibrations of the tires when I test drove the truck and I mentioned this to the salesman and he replied that he could fix it. However, when i took the truck back to the dealership, they said they had fixed the problem but my tires still have the vibration and bounce. They claim now that it is the type of tire it is and that their is nothing they could about it. They said they balanced my tires but like i said before, the tires are still the same. What have you done so far about your tires? I have went so far as to call Detroit to main office and they replied that they can't help with the situation. I am thinking that this is a poor manufactoring company that can't correct their problems. What is your input on this?
on
i have the 20" and I notice they don't feel right unless the pressure all around is exactly the same. In cool weather, they drop a bit and need a more frequent top up.
Try an electronic pressure guage. You can get a talking digital one at Radio Shack for $5. Am running them at 40lbs and all is well. Good luck.
You might want to have another shop try to balance them. I bought a new FX4 with 18" BFG tires in August. When I went to buy it, they couldn't find the keys so I test drove a similar truck and it seemed to have a tire balance problem. The day I drove mine home it felt like it had a rear tire out of balance around 55-60 mph and I could even see the top of the bed vibrating up and down at that speed. I took it back 4 days later and they re-balanced both rear tires yet at the same time told me it felt normal to them and that "road feel is normal in this type of vehicle". They also blamed me for having "too much air in the tires". I reminded them that the truck was only 4 days old and I had not even checked the tire pressure since their tech prepped it and put his initials on an pre-delivery inspection sticker inside the windshield. It was slightly better but still not good enough so I took it to my favorite local tire shop. They are small and simple, but do good work. I had recently tipped the technician after he installed tires on our car because he always does a good job and torques the lug nuts properly. He found the left rear tire out of balance on my new truck and made it right. It only cost me $20 ($12 for balancing and an $8 tip with a suggestion he spend it on a couple cold ones after work).
I have the 20" and I notice they don't feel right unless the pressure all around is exactly the same. In cool weather, they drop a bit and need a more frequent top up.
I would have to agree with this one also. I have had issues with my 20's due to low air pressure and balance issues. Have them re-balanced and maintain 40 psi. At 35 psi the tires will flat spot overnight and be miserable for the first 1-4 miles until they round back out.
Good luck!
Mike Aka QKADCT
'06 SCREW FX4
"Waiting on those crappy Pirelli's to wear out for some 325/55/20 BFG KM2's"
Good luck!
Mike Aka QKADCT
'06 SCREW FX4
Good luck!
Mike Aka QKADCT
'06 SCREW FX4
Good luck!
Mike Aka QKADCT
'06 SCREW FX4
I have the same setup on my 07 FX2. I'm not sure if it's the tire compound or what, but I too notice that if I don't drive the truck for a couple of days, the tire gets a "flat spot" and after a few miles, it goes away.
Good luck!
Mike Aka QKADCT
'06 SCREW FX4
Good luck!
Mike Aka QKADCT
'06 SCREW FX4
I bought New 285 18 Silent Armor this summer. I have had a night mare getting them balanced. I have been back three times, and I went to another shop and paid 120 bucks and they still vibrate. I mean come on, balancing is a no brainer. I paid way to much for those tires, and they are on a Lariat. I feel a law suit coming on here. I know one thing, I ain't going down and sitting in the Good year tire shop for another three hours, to try and get my tires balanced. I figure maybe they need to hire REAL tire techs, instead of grabbing someone off the street and paying them 5.75 an hour!
Man I am so mad I could pop!
I'm not saying this is the problem with the 20's on the fords but it might warrant some looking into, especially if the vehicle sat on the lot for more than a couple weeks before it was sold.
