You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
i know some peole with veggie converted mercedes add 1/2 gal of gas to there tank of veggie. i have never done this in mine but saposivly works for really cold weather.
__________________ 2011 Escape Limited v6 (Loaded) ESP 7yr/65k and Full Ford Maintenance Plan
2005 F350 6.0 (modded) ~450rwhp/900+ft/lb tq
1999 F350 7.3 (normal mods + 13" King Suspension on 40's)
1998 F150 (basic mods + 7" Suspension on 35's/Prerunner fiberglass and skidplace)
1994 Bronco (normal mods + 9" Coil Suspension on 35's)
Yes, the RUG thins out the oil and also produces a chemical change to the oil so that it does not 'string' when pushed through the injectors. This will help avoid coking of the injectors and rings. It's also a good idea to add a cetane booster to the mix to help smooth out the combustion process.
Gas has been a winter additive to diesel for decades. It helps to thin it out and prevent clouding in the cold.
I normally run about 20% #2, 75% WVO, and 5% Reg Unleaded. My truck still doesn't have the power it has with straight #2, but a lot more than it did with straight WVO. I do know that an old volkswagon diesel a friend of mine has recommends up to 20% gas mixed with the diesel in the winter, so obviously you can go up pretty high with it. I am considering switching from gas to just putting propane injection on my truck, but I'm not sure about it.
Do you have any proof that gas "produces a chemical change in the oil (sic Veg Oil)". I do not believe that is possible.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
Why would it have to produce a chemical change, its not supposed to produce a change, just thin it down, gasoline is very thin, as opposed to veggie, which is extremely thick. It makes flow and filter better.
