Temp sending unit location
Old 05-19-2002, 05:24 PM
cw50must's Avatar
cw50must
cw50must is offline
Where is the temperture sender location on my motor? My gauge isn't working and I'd like to find the sender but can't seem to locate it.
Old 05-19-2002, 07:10 PM
mantta's Avatar
mantta
mantta is offline
What engine you got?
Old 05-19-2002, 10:22 PM
cw50must's Avatar
cw50must
cw50must is offline
Um, '84 300 with a carb
Old 05-19-2002, 10:52 PM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
The sender for the guage is on the passenger side of the head towards the rear, kind of a tricky place to get to. You may have another temperature sender near the thermostat housing if your truck has a computer; it doesn't affect the guage though.
[font color="green"]1995 F-150 Supercab XLT longbed 4x4 302 M5OD [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old 05-20-2002, 11:11 PM
cw50must's Avatar
cw50must
cw50must is offline
Ok thanks. That's what happens when you stretch out these things, I'm sure I forgot to hook it back up when I had the head off about a year ago, but I just now got it running again. I'll hunt around for it.
Old 05-21-2002, 09:06 PM
cw50must's Avatar
cw50must
cw50must is offline
I found it. Thanks, Can someone verify the correct wire for me. There is a wire in a plastic loom that is hooked into a bracket right behind the head. Is this the correct wire? I couldn't tell what color it was other than it was darak, it is cut off too so it has no end on it.
Old 05-21-2002, 09:18 PM
brown 4x4's Avatar
brown 4x4
That sounds like it, I seem to remember mine as a dark color. Haynes manual says it's red-white stripe.
Old 05-21-2002, 09:26 PM
Vampiro's Avatar
Vampiro
Vampiro is offline
kabcpapc
Modular V8 (4.6L, 5.4L)
09-06-2014 05:35 PM
SVTDriver97
06-10-2014 06:21 PM
PRIMERED79 SHORT BED
09-05-2013 09:52 PM
lm987
06-12-2013 10:32 AM
03SD6L
03-02-2011 11:14 AM
Quick Reply: Temp sending unit location
