Temp sending unit location - Ford Truck Enthusiasts Forums
Old 05-19-2002, 06:24 PM
cw50must cw50must is offline
cw50must is starting off with a positive reputation.
Where is the temperture sender location on my motor? My gauge isn't working and I'd like to find the sender but can't seem to locate it.
Old 05-19-2002, 08:10 PM
mantta's Avatar
mantta mantta is offline
mantta is gaining momentum as a positive member of FTE.
What engine you got?
Old 05-19-2002, 11:22 PM
Um, '84 300 with a carb
Old 05-19-2002, 11:52 PM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
The sender for the guage is on the passenger side of the head towards the rear, kind of a tricky place to get to. You may have another temperature sender near the thermostat housing if your truck has a computer; it doesn't affect the guage though.
[font color="green"]1995 F-150 Supercab XLT longbed 4x4 302 M5OD [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old 05-21-2002, 12:11 AM
Ok thanks. That's what happens when you stretch out these things, I'm sure I forgot to hook it back up when I had the head off about a year ago, but I just now got it running again. I'll hunt around for it.
Old 05-21-2002, 10:06 PM
I found it. Thanks, Can someone verify the correct wire for me. There is a wire in a plastic loom that is hooked into a bracket right behind the head. Is this the correct wire? I couldn't tell what color it was other than it was darak, it is cut off too so it has no end on it.
Old 05-21-2002, 10:18 PM
That sounds like it, I seem to remember mine as a dark color. Haynes manual says it's red-white stripe.
Old 05-21-2002, 10:26 PM
Vampiro Vampiro is offline
Vampiro is starting off with a positive reputation.
Location of water temp sender and oil pressure sender kabcpapc Modular V8 (4.6L, 5.4L) 1 09-06-2014 06:35 PM
Oil pressure sender location? SVTDriver97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 06-10-2014 07:21 PM
79 fuel sender PRIMERED79 SHORT BED 1973 - 1979 F-100 & Larger F-Series Trucks 14 09-05-2013 10:52 PM
Temperature Sender location. lm987 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 06-12-2013 11:32 AM
trans temp sender 03SD6L 6.0L Power Stroke Diesel 17 03-02-2011 12:14 PM
Tags
1999, 49, 73, 99, car, ford, lincoln, located, location, sender, sending, temp, temperature, town, unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
