Stuck in 4WD? - Page 3 - Ford Truck Enthusiasts Forums
Stuck in 4WD?
  #31
Old 03-14-2014, 08:36 PM
ironbandit ironbandit is offline
ironbandit is starting off with a positive reputation.
4WD fixed and working...
It took me the better part of 4 hours to get both sides and the solenoid replaced, but we had a warmish afternoon, finally, here in MD. Main issue was getting the bottom of the strut back into place. We did it with the front end on jack stands, and the wheels off. The passenger side front was engaging, and the driver's did when I knocked the half shaft loose. Still. I had new actuators and a solenoid, so I replaced them all. Now, I can hear a vacuum leak on deceleration, and I will see if I can track that down tomorrow.
ARRRRRGGGHHHH....broken coil bolt. jtexfisher 1968-2013 Full Size Vans 17 01-25-2016 05:33 AM
Diff leaking at plug jtexfisher 1994.5 - 1997 7.3L Power Stroke Diesel 2 08-15-2014 06:11 PM
Stumbles sometimes dies when shifting to R jtexfisher 1994.5 - 1997 7.3L Power Stroke Diesel 4 06-30-2014 10:29 PM
Front end CLUNKING Helppp!!!! wittwayne 1999 to 2016 Super Duty 5 09-12-2013 03:41 PM
Clunking noises in 4WD. patsplace Clutch, Transmission, Differential, Axle & Transfer Case 7 12-07-2004 09:36 PM
Tags
2002, 2004, 2007, 4wd, drive, f150, ford, high, ingages, stuck, wd, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
