Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 11-13-2007, 02:22 PM
ss150 ss150 is offline
Garage is empty, add now
ss150 is starting off with a positive reputation.
Adding HP on 2nd Gen
My brother has an '03 Lightning that is currently at 400 rwhp. He is looking to take it to 450 rwhp, where he will hold off and start saving fr a new rotating assembly. His mods right now consist of a 6# lower, C&L air intake, C&L 95mm MAF, Accufab TB, C&L upper plenum, Accel coils, NGK TR6's, and a custom SCT dyno tune. What do you guys recommend he do to get the extra 50 rwhp?
__________________
'92 F-150 Flareside 302 E40D 3.55's
MSD cap & rotor, Flowmaster muffler
  #2 (permalink)
Old 11-13-2007, 03:50 PM
scottie2hottie's Avatar
scottie2hottie scottie2hottie is offline
scottie2hottie is gaining momentum as a positive member of FTE.
No2............
__________________
2002 F350 "Big White"
2001 F150 "Black Pearl"
1996 F350 "Red Sled"
Proud to be an OHIO BOY
  #3 (permalink)
Old 11-13-2007, 07:04 PM
wd13's Avatar
wd13 wd13 is offline
wd13 is gaining momentum as a positive member of FTE.
He's about tapped without nitrous, heads/cams, or different blower.Or He could always install every bolt-on know to man, spend a ton of cash and get close to that.
  #4 (permalink)
Old 11-14-2007, 06:31 AM
I was thinking he could get his Eaton ported, and then get a cat-back and be close enough to his goal. Once he gets a little closer to 450 rwhp, he's going to start with some traction mods.
__________________
  #5 (permalink)
Old 11-14-2007, 07:51 AM
nitrous is easy snd relatively inexpensive......
__________________
  #6 (permalink)
Old 11-14-2007, 08:22 AM
wd13's Avatar
Quote:
The cat back will do nothing for him in the power dept without going with hi-flows or even catless. As for the ported Heaton, I've seen good results on some. never in the 50hp range though.
  #7 (permalink)
Old 11-14-2007, 11:59 AM
He wants the power always there. No switches or refills.
I do know exhaust doesnt pull much hp on these trucks. He mainly wants a cat-back for sound, a couple rwhp may result though. He doesnt want to get a new mid-pipe though, because he has a mustang with full exhaust and he doesnt want another loud vehicle.
Porting the Eaton and have the plenum and TB port-matched, I would expect up to 35 rwhp. That will probably be enough, as with tuning and a tad smaller belt, he should be able to get it tuned around 440 rwhp.
Is there any power to be had in upgrading the cooling system, like electric fans and heat exchanger?
__________________
  #8 (permalink)
Old 11-14-2007, 01:06 PM
power gains in upgrading the cooling sys are nominal.....
__________________
  #9 (permalink)
Old 11-14-2007, 01:30 PM
MisterCMK's Avatar
MisterCMK MisterCMK is offline
2007 Ford F-250
My Garage
MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.
Toss a whipple on there.
__________________
Chris - Avid Winter Hater
2007 F-250 XLT 4x4 CC SB 6.0 PSD - ARP, IPR GEn2 EGR Delete, 4" turbo-back, no muffler, no cat, 6.4 banjo bolts, SCT X3, Tenney 270A alt, coolant filter, air bags, Ranchos, etc.
1994 Mustang GT - HCI, MM suspension parts, etc Novi2k waiting on the shelf
Hope & A Prayer Motorsports
  #10 (permalink)
Old 11-14-2007, 07:57 PM
commandersander's Avatar
commandersander commandersander is offline
2003 Ford F-150
commandersander is starting off with a positive reputation.
Water/Methanol injection.
Cheap, easy, safe.
Water and methanol injection kits offer chemical intercooling and power simultaneously to add power to your car or truck. Water, with its high latent heat of vaporization, cools the intake charge and combustion. Methanol also cools the charge and combustion, but also acts as high-octane fuel (up to 120 octane) and adds more oxygen to the combustion. These water and methanol injection systems contain everything you need for more horsepower, and are great in gasoline supercharged or turbocharged vehicles and diesel applications.
  #11 (permalink)
Old 11-14-2007, 08:18 PM
MisterCMK's Avatar
2007 Ford F-250
My Garage
I wouldn't do a meth kit for a street vehicle. You need to have a place to mount the resivoirs and you have to plumb it in. Not a big deal, but still something to remember. The big thing about them is that you don't know when it is not working so you risk trashing your motor. You have to buy product which is around $6 a gallon. Also, it would require tuning if you plan on making big power.
__________________
  #12 (permalink)
Old 11-14-2007, 11:46 PM
2003 Ford F-150
So on my Fox....
The resivoir duty was handled by the washerfluid tank that already exits in the fenderwell. In the truck, there is more room....even in the front bumper, behind the grille....there are places....
Beyond that, the plumb is waaay easy.....much easier than N2O....even a "dry" system...
You are dealing with low pressure, with the pump drawing a minimal amount of current and a psi level around 150. In the intake runner post MAF but pre TB.....as you would a dry N2O nozzle...
There are add-ons you can get like a float switch to let you know when you are low on the mix....and that can trigger an led inside....alonlg with solenoids to activate the boost bypass valve....and even a boost controller..
The mix? Easy. Winter formula for windshield washer fluid. It really is JUST THAT SIMPLE. For around a buck a gallon, you can experience an increase in RWHP of a 100+......
The concept is to provide an atmosphere for you to better realize the potential power that is stolen from you EVERY time you drive due to lack of boost, charge temp, timing and detonation. Water/methanol fixes it....safely.
No tune needed....just increase your timing 2degrees at a time and do a third gear pull. No detonaton....go for another 2 and repeat. Once you detect detonation, back it down two and you're done....
Check out snowperformance (there are others as well) if you want more info...
  #13 (permalink)
Old 11-15-2007, 12:53 AM
MisterCMK's Avatar
2007 Ford F-250
My Garage
Personally, I wouldn't risk my motor to a $1 jug of windshield washer fluid. Yes, you can, but its better to use an actual meth mix as you don't always know how pure the washer fluid is.
Yes, the plumbing is easy, I'm just saying that it is something to consider. More parts/complexity = more things to go wrong.
__________________
  #14 (permalink)
Old 11-15-2007, 08:41 AM
wd13's Avatar
There are a few hp to be gained by switching to e-fans as well as going to a Cobra R water pump. Its all part of the bigger package.
  #15 (permalink)
Old 11-15-2007, 08:47 AM
wd13's Avatar
Quote:
What kind of add ons do they have for protection when the pump quits on you and you're way over timed and under WOT?
It all sounds great in theory but for me, I'll stick to running timing/boost that I have octane to cover.
Tags
2nd, add, ford, gen, horsepower, lightning, mods, safe, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
