Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 05-24-2002, 09:21 AM
Justin03PSD's Avatar
Justin03PSD Justin03PSD is offline
diesel n00b
Justin03PSD is starting off with a positive reputation.
intermittent stutter / hesitation under load
I really appreciate the continued input, fellas!
I believe I have finally located the exhaust heat up valve thingy you guys are referring to. It's at the bottom of the exhaust manifold, right? It was partially hidden by the heat shield but I saw a spring and lever type contraption back behind it. I need to replace the manifold gasket anyway, and this give me an even better reason to take it off. I'm going out of town for the weekend but will report back after I've completed the wrenching. Any gotchas you guys can think to warn me of before hand?
Have a good holiday y'all!
Justin
__________________
2003 F-250 XLT 7.3 crew cab 4x4
Zoodad, 6637 covered by Pete, AIH delete, Magnaflow #17979 4" exhaust, DP Tuner F5 chip 40T / 80E / 120R, Autometer #3804 boost and #3845 EGT gauges
  #17 (permalink)
Old 05-28-2002, 04:23 PM
diesel n00b
Well folks, here's the latest...
Yesterday I pulled the manifolds off to replace the gasket and get at that butterfly device in the exhaust manifold. Before tearing it apart I took the heat shield off and played with the weight on the end of the butterfly. I could move it by hand but found it would not move on its own no matter how hot the engine got.
After getting the manifolds separated I took the spring assembly off the butterfly and shimmed it in the open (exhaust going out the manifold rather than up to the intake) position permanently. I also bought a sheet of 22 guage metal and toyed with the idea of creating a plate to block that passage off completely, but ended up not doing so, thinking it'd throw off the alignment of the manifolds and I wouldn't be able to get them bolted back onto the head.
I did some other small stuff, like buying plugs for the EGR tube (since the valve has long been non functional) and removing old vacuum lines for the extinct smog pump, EGR, A/C, etc.
Got it all buttoned up and went for a test drive last night. It never got hot or bucked / jerked / hesitated, but there is still excess pressure in the system and it again blew the PCV valve out of the valvecover. I put a vacuum guage on it today and came up with the following readings. At idle it jumps between 17 and 18 inches. Blipping the throttle it would drop to 4-6 inches, up to 22, then back down to 17-18. Holding it steady at 3k RPM, it raised up to about 20, then when I let off it peaked at 22 then settled back down to 17-18. I don't know what "excessive" needle fluctuation mentioned above equates to, but other than the jumpy needle my readings seem pretty decent. The jumpy needle did happen across the board, and would fluctuate 1 or 2 inches. Is this indicative of a bad head gasket? I need to do a pressure / leakdown test to see what the rings say, but I foresee more wrenching in my future regardless. As usual any and all input is greatly appreciated.
Justin
__________________
  #18 (permalink)
Old 05-28-2002, 04:45 PM
hotrodford_88 hotrodford_88 is offline
hotrodford_88 is starting off with a positive reputation.
According to my chiltons manual, a jumpy needle could be an indicator of the following:
Weak valve springs
worn valve stem guides
or
A Leaky head gasket
__________________
1965 F-100, 390, Edelbrock Performer RPM, Holley 600, Pertronix ignition, Edelbrock Performer Cam, K&N Air Filter, Flowmaster 2 chamber mufflers, Heddman Headers, A/C, Lokar transmission mounted shift
  #19 (permalink)
Old 05-28-2002, 07:33 PM
gray79f250 gray79f250 is offline
gray79f250 is starting off with a positive reputation.
Tags
2300 , carb , holley , load , stutter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
