Im thinking of putting a kenne bell on my 04 L, any imput would be nice. THANKS
Mods/
cai
bassanni exh
Greeat mod! Make sure to install the 255 pumps, 60lb injectors, colder plugs, and a Mafia or equivelant, and get a good tune. If you're on the stock block I'd keep it 17lbs or less. Thats about it
So it 's not just a bolt on and go,thats more than I was told from my local shops.17lb is safe on a stock block and heads? Sounds good thanks for the info.
cai
bassanni exh
cai
bassanni exh
Sure, you can bolt it on and go. It likely wont last though. At minimun you need a tune.The other stuff is good insurance and SHOULD be used. Nothing like skimping on parts just to save $ only to spend double that to repair all that was ruined b/c of it. lol And yes, 17lbs (max) would be ok with the mods I previously listed and a good safe tune.
