351w??? casting numbers - Ford Truck Enthusiasts Forums
Old 11-12-2007, 09:31 PM
F4L956 F4L956 is offline
F4L956 is starting off with a positive reputation.
Thumbs up 351w??? casting numbers
A brother-in-law has an engine his trying to fix up to put into a 56 f100 but yet has to figure what block he has this all he found i did a lil searching here but didnt get far but a lil closer...
1) W1FK 408AA------ around where starter goes
2) 351WCP21----- just below where head goes
3) JX168898---- in bell housing or somewhere around there
it was dark when he got this #'s might have read them wrong
any help appreciated thanks !!!
Supposely guy he got it from said it was out of a crown vic. but had it in a truck.
Old 11-14-2007, 01:47 AM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
2) seems to confirm it's a 351
Ask him to double check 1) as it's really different from what one would expect on a small block Ford. The AA suffix is the only part that seems plausible.
Old 11-14-2007, 10:54 AM
thanks for the reply!~
we got a new casting number as follows
>>>>>>>> E4AE 6015 FA21 <<<<<<<<<<
.......................BB 2................. on bottom
Any guess??????? THANKS FOR ANY INFO! =)
Old 11-14-2007, 11:21 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
About all I can tell you is E4AE is a 1984 casting number. But casting numbers do not translate to actual part numbers.
All the 1983/88 351W's use the same bare block. Ford part number: E3AZ-6010-B.
To find out for sure what you have, you can contact FTE sponsor Direct Ford Parts. Their link is on the forum main page. You may have to refresh till it appears
1981 F700 370-2 Lil Dick Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 07-28-2012 09:27 PM
4 speed makin noises Lil Red Sled 1973 - 1979 F-100 & Larger F-Series Trucks 3 06-19-2011 01:21 PM
which is the best motor the 351m ,351w, 351c texml69 1973 - 1979 F-100 & Larger F-Series Trucks 27 01-04-2011 04:59 PM
ACV where and how does it connect Dewop 1987 - 1996 F150 & Larger F-Series Trucks 8 11-15-2006 01:22 PM
Can you put 351W heads on a 302? 1988XLT2002 1978 - 1996 Big Bronco 6 09-28-2002 07:37 AM
Tags
14, 1984, 351, 351w, 351wcp21, 88, aa, block, casting, castings, e4ae, ford, head, location, number, numbers, suffix
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
