Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation & A/C
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Cooling, Heating, Ventilation & A/C SPONSORED BY:
Click Here
  #1 (permalink)
Old 11-12-2007, 07:08 PM
weswes01 weswes01 is offline
Garage is empty, add now
weswes01 is starting off with a positive reputation.
Can a bad engine temp sensor cause a high or changing idle??
i have an 86f150 with an 88 fuel injected 4.9l. my truck recently developed a high idle (around 1450 rpm). but sometimes it idles perficlty. as it warms up it seems to get slightly higher. At times it also has a dead spot as soon as i touch the throttle. i have repaced the iac and the tps sensors already in hopes of fixing it. yesterday i scanned it and i got code 21 coolent temp sensor out of range. but my temp gauge works just fine. cold this be the problem?
  #2 (permalink)
Old 11-12-2007, 09:08 PM
jimdandy jimdandy is offline
jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.jimdandy has a good reputation on FTE.
The engine coolant temperature sensor is not the gauge sensor. Two different components. The ECT will have two wires, and the gauge will have one wire. The ECT acts kind of like an automatic choke works on a carbed engine. The computer checks the ECT for engine temperature at start up to see if more fuel is needed if the engine is cold, or less fuel if the engine temp is hot. Depending on how the sensor fails, it can cause hard starting when cold, erratic idle, etc., but once the engine is warm the engine starts ok. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
Tags
automatic, bad, badly, choke, cold, coolant, engine, guage, heat, high, idle, sensor, temp, temperature, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
