There are some things to clarify:
All car 5.0's are SEFI
All truck SD 5.0's are batch fired
1996-2001 Explorer 5.0L are OBDII
Don't mess with the injector wiring as that will interfere with the O2 sensors. It messes with the fuel balance. The computer will try and correct the fuel mixture of that cylinder but it won't know it's on the other side of the engine.
A stock computer won't be able to handle a different engine and a blower without tuning. You have to reset the engine size, fuel injector size and many other settings. Just get Tweecer and be make the necessary changes.
__________________
 Nathan  TM
You may have an Effie but I have a Emmie!
'51 Mercury M-3 Extra 5 Star Cab Dually "Faith"
That is sitting on a '78 F-250 Supercab frame with F-350 axles.
Built to play and work hard!
Frame Swap Tech Article
