Vacuum pump stays on
11-12-2007, 05:21 PM
on
When I cycle the key the vacuum pump does not shut off even after starting the engine. Also noticed that the Max A/C setting was very slow to go to recirculate mode a couple of weeks ago. Is there a leak or did the pump take a dump? Any body have this prob? '04 6.0 39K miles
11-12-2007, 05:39 PM
If the pump is constantly running and your A/C is slow to switch from defrost to vents, then you have a vacuum leak somewhere.
you have a leak somewhere. do you have a 4wd?
11-12-2007, 06:04 PM
on
Yep, 4x4. How do I find the leak?
11-18-2007, 02:49 AM
on
I found the leak. The line to the heater hose valve was disconnected. Thanks for the feedback !
11-18-2007, 12:54 PM
great job. glad it was a easy fix.
11-18-2007, 01:05 PM
Quote:
Aren't they all that easy
11-19-2007, 06:48 AM
endobear
17
04-08-2014 09:49 PM
garrettsr5
05-15-2013 04:09 PM
Jaaaaaaackman
03-10-2012 08:53 PM
poocher pup
10-17-2010 11:25 AM
rugermack
1999 to 2016 Super Duty
07-25-2008 09:13 PM
60 ,
73 ,
asevacforsale ,
diesel ,
excursion ,
f250 ,
ford ,
pump ,
stays ,
vaccum ,
vacuum
