2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Problem Seeing Guages
Old 11-13-2007, 10:08 PM
Newton007's Avatar
Newton007
Newton007 is offline
What I am seeing is I can't post attachments. So does this mean that I can't post a picture? I don't know how this works.
Old 11-14-2007, 10:41 AM
berry1234's Avatar
berry1234
berry1234 is offline
Originally Posted by Newton007
I will see what I can do with my digital camera.
But I am not sure how to upload a picture to this site as I am not a computer person.
But may be able to figure it out if I start punching a lot of buttons on this here comp-u-tu-ter.
You have to 'host' the pictures on a site some are free, some are pay, then enter the link to the site. If you email me the pix I will host them for you.
Old 11-14-2007, 10:52 AM
rich93cw's Avatar
rich93cw
rich93cw is offline
I have no doubt that there are many other owners besides you and me that have difficulty seeing the gauges. Whatever you can do to guide us will be very appreciated. Sincerely, Rich
Old 11-14-2007, 12:26 PM
berry1234's Avatar
berry1234
One thing I thought about. The needles are almost translucent and the light comes through them so to speak-almost a glow. Will painting them stop this?
Old 11-14-2007, 12:43 PM
rich93cw's Avatar
rich93cw
rich93cw is offline
I'll bet that they are pink at night!
But, if they are more visible, I say, "Who cares!"
Old 11-14-2007, 01:54 PM
Newton007's Avatar
Newton007
I will try to get some pictures, but there is really not much to see as now the red indicators are white is really the only difference. Yes now the indicators are sort of pink at night now but white in the day when you really need to see it.
One important note is to use water based paint, hobby type only as anything else may melt the indicators. I would NOT use automotive touch up paint in the little bottle.
The hardest part is taking off the clear plastic face plate. There are several plastic tabs that must be taken loose. It is kind of tricky, but it can be done. Plus I did not disconnect the dash board wiring, just lifted it out a ways.
I found the white paint in the crafts dept. at Wal Mart. I used a very small brush. Total cost about $3.50 When painting use a lot of paint on your brush and just dab it on the indicators only. Be careful not to make a mess of things. You may want two coats of paint, but one good one seemed to work ok. The whole thing took about an hour to do. It helps also to have the ignition on so the indicators are more toward the center of the gauge.
Now I see the gauges just fine in the day and night too.
Old 11-16-2007, 06:05 PM
berry1234's Avatar
berry1234
Old 11-16-2007, 06:25 PM
Newton007's Avatar
Newton007
Thanks Berry 1234 for helping me out on this.
I hope this helps if you should do this to your Expedition. It only took about an hour or so and was well worth the time. I will try to answer any questions about doing this.
I hope the Ford person monitoring this site takes note of this modification as before I did this I could not see a %$#&*(^) thing during the day.
I know you are not to use words like %*^%@#@ or even *^%##@ on this site but but this gauge indicator readability problem on my new $40,0000 SUV made me say it.
Old 11-16-2007, 06:33 PM
berry1234's Avatar
berry1234
Let me try to resize these babies.
Thats better.
Old 11-16-2007, 06:42 PM
Newton007's Avatar
Newton007
Thanks Berry 1234.
Looks good. They look better at night than the pictures show as it is kind of hard to get a good close up focus on the digital camera in the dark.
Old 11-16-2007, 06:43 PM
berry1234's Avatar
berry1234
No problem.
Old 11-16-2007, 07:23 PM
Newton007's Avatar
Newton007
OK, I had too many 0000s. It was $40,000 not $40,0000. It just seems like $40,0000 when I write the bank a check every month.
  #28
Old 11-16-2007, 09:17 PM
IQ9's Avatar
IQ9
IQ9 is offline
Looks good. Its nice you only needed toll paint,nothing expensive except your time. Great job!!
  #29
Old 11-17-2007, 01:12 PM
rich93cw's Avatar
rich93cw
rich93cw is offline
Newton007 and berry 1234,
Thanks for the great solution and photos. That will be my next project!
Rich
  #30
Old 11-17-2007, 08:40 PM
Newton007's Avatar
Newton007
Rich 93 CW,
Try one coat of paint first as this usually works. More than that may cause night vision of the indicators to be not as bright.
Also now that I think about it I did not stir up the paint first so this may have helped with the translucent part.
Actually one good coat seemed to work ok as the point is to just have a white surface on the indicators, not a heavy duty paint job. Put a lot of paint on a very small brush and just dab it on. It looks like a lot of paint at first, but it is mostly water and when dry flattens out ok.
I would try one coat first, see how it looks in the day and at night. You can always put more on, but no way to to remove it if too much.
Those little plastic tabs on the face plate was the hardest part of the whole job. They are kind of tricky to take loose. Also a little socket wrench with extention helps too with the screws.
It is really not as hard as it sounds to do, it just takes some time as I was working through the steering wheel.
I think you can unplug and remove the panel, but did not do it as I am not sure if this does something to the electronics or not. I would not think so, but who knows. May be someone here knows if this is ok to do.
Let us know how it goes.
Quick Reply: Problem Seeing Guages
