If any body has some good pics of the their w/m installed on a super duty I would love to see them. My setup is not working out like I had planned. Also, I bought my kit from Jeggs and called and talked to Nate at snow perf today due to some probs I was having with the pump and he told me that the kit I got must have been sitting on the shelf for years because that parts were way out dated. I would suggest ordering direct from Snow if anyone is thinking of buying.
Sorry guys, I haven't been around this site as much. Ok, why did I get rid of mine? Because I combined it with NOS, 64mm turbo, 225cc injectors and blew a hole in the block and left 9 lbs of scrap metal in the oil pan.
Word to the wise, if you're heavy modding, look into beefing up the low pressure oil system. If it comes apart like mine did, you're screwed.
As for the Snow System, I think it's a GREAT system. I will have one again. I sold mine to get some money to pay things off. Nothing like having an 06 truck with an 04 motor. lol
Sorry to hear about your motor. I will not be going too crazy with my system. I have an 04 with Airaid intake, Intake elbow, MBRP turbo back, SCT with tow and race tunes. I will be running 95% on tow safe meth and at the track of course xtreme race meth. Best ET without meth was 13.5. Looking for 12's in cold weather.
I just ordered my kit. Tunes are loaded in the SCT from ID. Can't wait. I ordered myself a 8 gallon tank which will be mounted in my tool box as I am going to try and use the Meth all the time. How long will 8 gallons of washer fluid last driving normal ?
I said that onece too. Once. ROFLMAO
Quote:
A long time if you ordered the Stage III as it works off boost and EGT so it controls it better. I had a ten gallon aluminum tank in my bed for mine. I got one tank of Meth to 2 tanks of fuel when operating on a tow program and keeping the Meth set to come on under higher boost and temps. It really didn't come on alot. Also, I had the two biggest nozzles you can get. You may not need those huge ones, so yours would use even less. When I was just driving around town I would lower the meth mix by diluting the washer fluid bottle for bottle with distilled water. Straight water still helps, so it was still a noticable power increase.
You said 2 nozzles. Will I be installing 2 nozzles on my intake ? Reason I ask is I ordered a weldable bung for my thin wall intake. I may need 2.
Also, I have a boost gauge tapped into my intake. I assume I mount the sprayer away from the boost bung. Where is the best place ? Also does the Stage 3 come with the low level indicator ?
