Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 06-04-2002, 08:08 PM
Pensive Pensive is offline
Pensive is starting off with a positive reputation.
Leaking Oil Pan
Thanks guys..I feel better already.
Auto parts place nearby has the gasket for $20 so that is a hell of a lot better than $500 for a dealership to do the work!
Does this thing get hit with gasket cement?
Does to oil pan (after hearing it is made of tin foil) need any special tightening instructions?
Or is it just a "put it in place tighten it down normally and go about your business" type thing?
Thanks again!
James
'93 F150
130,000 miles
  #17 (permalink)
Old 06-04-2002, 08:13 PM
Silver Streak Silver Streak is offline
Silver Streak is gaining momentum as a positive member of FTE.
Leaking Oil Pan
If it's a cork or paper gasket I would use some gasket adhesive on it and some RTV in the corners, then tighten it down. If it's a silicon/rubber gasket don't put anything on it except at the corners. Use RTV at the corners to help it seal properly. BTW, when I say corners, I mean where the gasket goes into the corner at the timing cover and rear main cap, not the corners of the block.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
  #18 (permalink)
Old 06-06-2002, 10:04 AM
tranthac1 tranthac1 is offline
tranthac1 is starting off with a positive reputation.
Leaking Oil Pan
I posted this on 23-may-02
I have been seeing problems concerning “Oil Leaks” that looks like it’s coming from the rear main seal or you can’t tell where the oil is coming from. I have a ’88 F-150, 4.9L that had the same problem. (Oil on the pan, manual tranny, bottom of frame and every where else. It appeared to be coming from between the bell housing and the oil pan. Oil all over the starter. It turned out to be coming from the oil pan gasket right rear corner. Some how the gasket was protruding out on that corner. FIX: Loosen the bolts on that side of the pan and pushed the gasket in ¼” and re torque the bolts. Added a can of CD2 stop leak….Problem solved. Still haven’t figured out the low oil pressure reading though.
  #19 (permalink)
Old 06-06-2002, 01:22 PM
stractor stractor is offline
stractor is starting off with a positive reputation.
Leaking Oil Pan
Hi as to the oil pan bolt sequence. There is a good description in the ford service manual and there IS a distinct sequence to tighten the bolts. If you don't have access to a ford service manual contact me and I will scan it and send it to you.
Bob /stractor
train.twosixo@verizon.com
:-staun
  #20 (permalink)
Old 06-06-2002, 02:22 PM
GammaDriver's Avatar
GammaDriver GammaDriver is offline
GammaDriver is starting off with a positive reputation.
Leaking Oil Pan
could ya scan it and just post it here? (or send it to me and I'll attempt to post it on this thread if you don't have web-space access.)
__________________
1999 F-150 XL, Extended Cab, Long bed, 4.6L, 4x4, M5OD (geez, the truck's description is just about as long as the truck itself! )
  #21 (permalink)
Old 06-06-2002, 03:51 PM
Leaking Oil Pan
GammaDriver ,I can scan it no problem. I don't have any program set up to upload it to since I upgraded my computer and drives and switched to DSL. I can send a file to you but I need an address to send it to.
Bob
  #22 (permalink)
Old 06-07-2002, 04:44 PM
Leaking Oil Pan
Thanks to stractor:
http://www.countryvue.com/oilpan.jpg
http://www.countryvue.com/oilpan2.jpg
__________________
  #23 (permalink)
Old 06-08-2002, 12:27 AM
a_Pink_Bunny a_Pink_Bunny is offline
a_Pink_Bunny is starting off with a positive reputation.
Leaking Oil Pan
the oil pan gasket on my 81 is leaking because it's weak, but as for the rusting out my truck has over 260,000km and its got the original oil pan, it must be where you're located as to how it rusted out so quickly.
  #24 (permalink)
Old 06-08-2002, 04:08 AM
SPROCKET's Avatar
SPROCKET SPROCKET is offline
SPROCKET is starting off with a positive reputation.
Leaking Oil Pan
I replaced my gasket at 85000..it was realy easy...only took about 30min with all the tools/parts handy. Just unbolt it and let it reast on the cross-beam and just weazel the new rubber gasket in and bolt it up...very simple job.
__________________
96 4.9L(BIG 6) F150 Eddie Bauer Reg. cab, 5 Spd,
Hurst Shifter, Gibson Supertruck exhaust, Catco Highflow cat, K&N FIPK w/cold air induction, dual 14" electric fans...much more
  #25 (permalink)
Old 06-08-2002, 08:03 AM
Gersty Gersty is offline
Gersty is starting off with a positive reputation.
Leaking Oil Pan
We just replace the Pan Gasket on our '94 F-150 also. Although it would have been easier to do with the motor raised, it can be done with the motor mounts secured. No big deal, just takes a little patience. The original gasket came right off, and with some careful positioning of the pan, side to side and front to back, there was enough room to clean the mating surfaces, and get the new Fel Pro Gasket in place. A little RTV in the corners of the main seal area, and the new gasket went right in. Could be difficult to get a Torque wrench on all the bolts, but just tighten them as if it were a Valve Cover Gasket, and your set. Thanks to everyone for the tips and advice."If you ain't the lead dog, the view never changes"
  #26 (permalink)
Old 06-09-2002, 07:00 AM
rtbstrd rtbstrd is offline
rtbstrd is starting off with a positive reputation.
Leaking Oil Pan
__________________
Peter B
'68 F-100 Ranger, 302/C-4 Swapped for the 240. '55 Country Sedan Hupbcaps
Tags
1988 , 49 , 4x4 , f150 , leaking , oil , oilpan , pan , wwwcountryvuecomoilpanjpg
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
