Door Swap - Page 3 - Ford Truck Enthusiasts Forums
Door Swap
  #31
Old 02-07-2012, 08:06 AM
bucks150's Avatar
bucks150 bucks150 is offline
bucks150 is starting off with a positive reputation.
My 91 has manual doors of of a 92. I'm wanting to put power doors back on it like it came out with. I know newer door will fit but will the 92-96 plug into the 87-91 wiring harness behind the kick panel.
  #32
Old 05-25-2012, 10:00 AM
homertwo homertwo is offline
homertwo is starting off with a positive reputation.
I would like to put the newer style front clip on my 1990 Super Duty.
Will I have to get the core support? Or will the newer fenders and grille bolt on?
If you have a nice rust free front clip, I would like to buy it.
Thanks
homertwo
  #33
Old 07-30-2012, 10:40 AM
cjcocn cjcocn is offline
cjcocn is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Reziac View Post
Been reading this thread and now I have questions too
I hate the power windows/door locks, and prefer the old-style panel look. Is it possible to just swap the innards and inside panel, and get the old-fashioned crank windows back? or would I have to swap the whole door?
Quote:
I just picked up a '94 ext cab short box 4x4 and currently it has manual windows and door locks.
I would like to put power windows and door locks on it.
A free bump for the two questions above as the answers to those should provide me with the information that I require.
  #34
Old 09-07-2012, 01:11 AM
tlillard23 tlillard23 is offline
tlillard23 is starting off with a positive reputation.
what does it take to put power windows/locks in to a non-PW PL truck? I have a set of power doors, just not sure if the harness is in the non-power truck. maybe I could just run some wires to the PW and PL?
  #35
Old 09-16-2012, 01:37 AM
89buriedtotheframe 89buriedtotheframe is offline
89buriedtotheframe is starting off with a positive reputation.
will 83 doors fit my 89? i have found a cheap pair to replace my beat up doors,and i want to sure they will bolt up before i buy them.
  #36
Old 02-08-2013, 09:44 PM
MrsOldHat MrsOldHat is offline
MrsOldHat is starting off with a positive reputation.
I have been wanting to know if I can put power windows in the back seat windows of my F350 CC. If anyone answers the earlier questions, I'll get my answer too!
  #37
Old 09-27-2013, 01:17 PM
RO241 RO241 is offline
RO241 is starting off with a positive reputation.
Ro241
I was wondering if a 2005 Crown Vic IFS fit on a 1989 F150 Chassis. I always read people doing it with older F100. I don't know if the chassis of my 1989 F150 is the same as 1979 F100. I'm trying to make my truck into a street truck, so I want a lowered stance
  #38
Old 09-27-2013, 04:47 PM
raystankewitz's Avatar
raystankewitz raystankewitz is offline
raystankewitz is gaining momentum as a positive member of FTE.
Old, dead thread
Quote:
RO241, you're posting in an old, dead thread.
Go to the front of the forum HERE, on the top left, is a button that says NEW THREAD. Click that button and start a new thread with your question. You might get better response than in this thread about doors, front clips and cabs.
HTH,
Ray
  #39
Old 09-28-2013, 06:41 PM
  #40
Old 09-28-2013, 06:46 PM
Thanks, first time on the forums
  #41
Old 12-14-2013, 11:00 PM
Charles_Richards's Avatar
Charles_Richards Charles_Richards is offline
Charles_Richards is starting off with a positive reputation.
Door skins
Quote:
Originally Posted by Conanski View Post
There is a bracket bolted to the door for the armrest, these things are different and have to be swapped, but that's it, the inside door skin will snap on. http://www.flickr.com/photos/motorst...7602815837039/
I got a pair of 92 trim panels at the U Pull but they poked out too far....sounds like I need to go back to the JY and pull the arm rest bracket. Thanks Conanski...again
  #42
Old 04-06-2015, 10:30 PM
Brendan_F150 Brendan_F150 is offline
Brendan_F150 is starting off with a positive reputation.
Fender Swap
My neighbor has a 1989 f150 with good front fenders on it, wondering if i can swamp them out for my rusted ones on my 1994 f150. i know this is for doors but couldnt find a thread for fenders.
  #43
Old 04-07-2015, 01:33 PM
Sure you can. But if you swap fenders. You need to swap the whole front end.
They are different. Will swap, but are different.
Door handle lock ??? Roger C 1961 - 1966 F-100 & Larger F-Series Trucks 7 11-30-2015 02:20 PM
Replacement Crew Cab Doors 0500757Arf 1987 - 1996 F150 & Larger F-Series Trucks 19 11-01-2015 08:19 AM
Door Lock Problems Roc53ky 1999 to 2016 Super Duty 1 08-08-2015 07:29 PM
49 F1 door latch assembly Trussonistephen 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 02-16-2015 01:39 AM
are there different door sizes on 70's models? wildcard221 1973 - 1979 F-100 & Larger F-Series Trucks 14 02-15-2015 12:35 AM
Tags
150, 1987, 1996, 87, 88, a89, door, drivers, e350, f250, ford, interchange, skin, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
