Brake Line Junction Mount - Ford Truck Enthusiasts Forums
Old 11-11-2007, 05:50 PM
eman92082's Avatar
eman92082 eman92082 is offline
Monkey-Face in Your Face!
eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.eman92082 has a great reputation on FTE.
As you can see, I have a few holes to fill. I know Henry's Engineers didn't do things without a reason. On my other Street Rods, I ran my Brake Lines through my Frame with a bulk-head fitting.
Does anyone know why they chose to use this bracket ? Seems redundant. But I'm not gonna remove it if there is a sound reason to keep it.
Dawg-a-saurus
Old 11-11-2007, 07:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
That's where the front brake lines change to rubber hose. There is a fitting and clip to hold the fitting in place.
Old 11-11-2007, 07:26 PM
eman92082's Avatar
Understand that. but was the bracket serving a design purpose or just "there" ?
Thanks
Old 11-11-2007, 07:29 PM
bobbytnm's Avatar
bobbytnm bobbytnm is online now
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
I think it's "just there" It was alot easier for Ford to rivet on a standardized brake line bracket than it was for them to design a bulkhead style through the frame mount.
I say that if you want to take it off and route your through the frame to clean things up then go for it!
Woohooo
Bobby
Old 11-11-2007, 07:50 PM
ALBUQ F-1's Avatar
postin' fool
Of course it serves a design purpose! With the line mounted in this bracket, the hose will not twist or tangle with anything over the complete range of suspension movement and steering angle. It also allows a different bracket to be used for the larger trucks, or COE's, etc. with different suspensions. If you replace it with something else, be sure your location guarantees the same. If you don't have stock suspension, the stock bracket location may not be correct.
Old 11-11-2007, 08:03 PM
eman92082's Avatar
"Of course" is not so damned obvious to me.
Thank you for the information. I've watched you for a while and I've determined you are are rude, self-important know-it-all...
I'm outa-here
Don't bother replying
Old 11-11-2007, 08:59 PM
CIAF's Avatar
CIAF CIAF is offline
CIAF is starting off with a positive reputation.
E-Dawgie, I would think that the design was to make it easier for assembly at the factory. Maybe the lines could be started and tightened quicker while the frame was traveling down the rail. Just a guess tho !!! I took mine out and used a different (tab) on my front when I re-plumbed it for disc brakes. They do look a bit strange if left there when you clean up the chassis. I like bulkheads anyway..
Jon
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
