Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-11-2007, 05:11 PM
jaandmk is starting off with a positive reputation.
02 F150 4.2L...Fuel trim
I Took the POS+ cable off for about two hours then hooked it back up. I started the engine then watched the engine with my scanner. I noticed the STFT was way off at 20+% (LTFT 0.00) while it warmed up....once the engine was warmed up I saw the fuel trim go to normal. What would cause the fuel trim to be way off while the engine was cold but go to normal once warm??
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-11-2007, 05:37 PM
Moore558's Avatar
Moore558 is starting off with a positive reputation.
Think about it. When your starting a cold engine, the PCM is going to have it run a little rich in order to get it warmed up and into closed loop quicker. That's should be normal on a cold engine.
__________________
Chrono
Farewell Baby. You will be forever missed. 03-29-96 to 07-16-2008
  #3 (permalink)
Old 11-12-2007, 04:02 PM
That does make sense, but its during this time that my lean codes are sent (closed loop, warming up). Thanks for the reply.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
