Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-11-2007, 08:13 AM
grefra is starting off with a positive reputation.
Need suggestions
I have a 1998 Explorer Sport, 4.0 SOHC.
I am stumped. The truck was ideling bad and running rough. I took it to the local Ford dealer and they suggested a tune up. They replaced the spark plugs and the fuel filter and said the fuel filter had restricted flow.
Thought all was well, but no.
Ran bad still, returned to the dealer and now, the IAC needs to be replaced, OK, did it. I am in to this $400 so far and it still runs bad, when in drive, stopped, foot on the brake, the truck dies.
I am thinking the dealer is a parts changer, and at my expense.
What else could the problem be??
Thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-11-2007, 08:55 AM
99f350sd is starting off with a positive reputation.
1st off I would have them put the old IAC back on and see if it runs any different. They really need to stop changing parts and diagnois the darn thing.
It must have run ok if they gave it back to you the first time??? So the problem is not happening all the time?
__________________
99 F350 5.4 Lockers,Warn winch,Hubs..Diablo Predator
MDII Plow, 200 amp alt timbrens,Revo's
85f150, THREE 96 aero*awd 4.0 ext. 05 mountaineer V8 Awd
Lever's are cool enough for me too...LOL
  #3 (permalink)
Old 11-11-2007, 09:14 AM
It does happen all the time. It happened as soon as I got the truck back, which was last week.
The old IAC which I kept is either really carboned up, or actually looks rusty inside.
I guess I will take it back, for god knows how much more it will cost to either put it on a scope or diagnose the problem and get it fixed, The truck only has 58,000 miles.
My neighbor has a little, big dollar diagnostic machine(hand held), I will see if he can check it and find out the codes.
Thanks
  #4 (permalink)
Old 11-11-2007, 09:29 AM
When you first brought it in they are supposed to diag the car..They did they said it needed a tune up WRONG wasn't the prob. They then should have diag the car again...said it needed an IAC Wrong Diag again...get your money back or take it to a diff dealer..I never pay for wrong diagnosis ,they are the dealer!!!!!!!!You bring it there cause they are the pro's ...You could of had your neighbor change parts...
__________________
  #5 (permalink)
Old 11-11-2007, 06:23 PM
Quote:
They have never diagnosed the truck. I am sure if I take it back and tell them I want it diagnosed since the $400 already spent didnt do it, they will charge me for the diagnosis.
Problem is the next closest dealer is 50 miles away/
  #6 (permalink)
Old 11-11-2007, 06:26 PM
I guess you are on your own...Give more info and we'll try to help if we can..
What does it do? how often? how long does it last? Everything...
__________________
  #7 (permalink)
Old 11-12-2007, 05:54 AM
marragtop is starting off with a positive reputation.
Check for vacuum leaks and get the codes pulled. There could be codes stored even if the CEL is out.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
  #8 (permalink)
Old 11-12-2007, 10:02 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
The tune up was wrong, thogh it was probably not a bad thing. They said the flow was restricted? I suspect there may be water in the fuel. Water in the fuel and clogged fuel filters often go hand in hand. Was the truck run out of gas or run lower than usual lately?
Pull the codes as a starting point, and then approach the problems that can cause a misfire. The IAC will never cause a misfire, though it can cause a rough idle. I would suspect the MAF sensor may be the problem, clean it. Next suspect would be the O2 sensor, remove and inspect. If it is light grey or tan, all is well, but if it is black or has any kind of deposits on it, replace it. Vacuum leaks will cause a misfire since they confuse the computer.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
  #9 (permalink)
Old 11-12-2007, 11:50 PM
We are going to get the codes tomorrow and I will post back. I already removed and cleaned,(looked spotless) the MAF/ What and where is the O2?
I have not ran out or low on gas ever since new. The check engine light came on last winter, I removed the negative battery terminal and reconnected, hope the codes are still there. Will a code show if it just dies without the check engine light coming on?
On the road the truck runs great, smooth and 20mpg at 65 mph without a/c.
Wow so many hoses and lines, I will try to figure out vacuum lines and if any look bad.
  #10 (permalink)
Old 11-12-2007, 11:52 PM
Would you drain the fuel tank and just try a gas drier??
  #11 (permalink)
Old 11-13-2007, 04:33 PM
Sponsor
No, just add a gas dryer, no need to drain the tank.
The O2 sensors will be either in the exhaust manifolds, or on the headpipes behind the manifolds.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
