I have owned my 1998 Ford Ranger XLT extended cab pickup for a few months now. The air conditioner just all of a sudden quit working on me. I have checked the coolant level on the low pressure side, and everything is fine. I've owned many Fords, just never a Ranger, is there a special fuse or switch to cause it to quit working....any help would be greatly appreciated.
It could be the relay in the electrical housing or it could be the clutch cycling switch mounted atop the accumulator. I'd say check both, (replace the A/C relay with another insig. one and check to make sure the clutch is cycling properly if that doesn't work).
Usually, if there's no refrigerant leaking, it's an easy fix. I have a leak in my evap. coil, so...
