Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Computer Chips and Tuners
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-10-2007, 09:52 PM
jmac71 is starting off with a positive reputation.
edge evolution 06 6.0 disconnected battery
i disconnected battery without putting back to stock. now i cannot get the trans to shift the same. do i have to drive it for a while to re learn?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-11-2007, 01:21 AM
dchamberlain is gaining momentum as a positive member of FTE.dchamberlain is gaining momentum as a positive member of FTE.
You shouldn't have to return to stock before or after disconnecting the battery. The edge flashes the programs into permanent memory. So most likely you are correct, the transmission simply needs to relearn it's conditions.
If you're concerned however, there would be no problem with returning it to stock and then reloading whichever program you normally use.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
