2002 Body Lift Help!!!!!
I am in the middle of a body lift on my friends truck its in the middle of my driveway and i cant get the cab mount bolts out. the plate on the bottom just spins!? what can i do to stop the plate from spinning as there is now way to get a wrench on there!! wth? i have seen rangers with body lifts before how did they get around this?! I need help asap!
I haven't done a body lift as I don't like them because it shows gapping between the body and frame plus bumpers. However, the easiest way when dealing with rusty or stuburn bolts is with cutting torches. I use them when doing exhaust or suspension work. If you don't have access to any, I don't know how to advise you, but maybe someone will have an answer for ya, so hang on .
95f150mudder
11-04-2011 11:15 PM
