Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 11-10-2007, 08:14 PM
Biggziff's Avatar
Biggziff Biggziff is offline
Garage is empty, add now
Biggziff is gaining momentum as a positive member of FTE.Biggziff is gaining momentum as a positive member of FTE.
Can't fill fuel tank very fast 05 CC LB
Seems that sometimes, when my tank is near empty, I can't fill it very fast without having the safety shutoff on the gas pump shut the fuel flow off. Doesn't seem to do it all the time, and happens more often when I get below a quarter tank. Even if I just trickle the fuel in, it'll shut the pump off...sometimes...
Vents seem clear... I hate the search on this forum..I searched for "Fuel tank fill" and "gas tank" and "Fuel tank" and got back everything from trailer hitches to tire pressure.
__________________
2011 F350 CC 6.7
  #2 (permalink)
Old 11-10-2007, 11:44 PM
Cowboy Brett's Avatar
Cowboy Brett Cowboy Brett is offline
Cowboy Brett is starting off with a positive reputation.
On diesels, you can harpoon the tank. I gather yours is a V10, though. I have no clue for those. I'll bump it back up on here for you, though...
__________________
2004 F-350 4x4 FX4 Crew Cab Short 6.0 TorqShift PSD
1998 F-150 4x4 Short 4.6L / 5 Speed Stick
Greetings from Out Wickenburg Way
Cowboy Up.
  #3 (permalink)
Old 11-10-2007, 11:58 PM
aldridgec's Avatar
aldridgec aldridgec is offline
2002 Ford F-250
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
Harpooning IMO is only good for getting the tank completely full, not helping it fill faster.
Do you always use the same pump, or is it different pumps doing this? Sounds odd. Not sure I have much suggestion, as the tank vent should allow the fuel vapors to bypass the end of the nozzle.
__________________
Chris
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
"Maybe is for those who lack skill"
  #4 (permalink)
Old 11-11-2007, 12:55 AM
jake00's Avatar
jake00 jake00 is offline
FTE is my crack
2007 Ford Expedition
jake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant future
I thought I read in the past to try not putting the nozzle all the way in the fill tube
__________________
Past rides
06 F250 CC v10 4x4 Lariat bought 5/08 for 20k sold 10/10 for 20K.
RIP BIG GREEN owned her from 08.17.04 - 05.10.08
  #5 (permalink)
Old 11-11-2007, 09:14 AM
redford's Avatar
redford redford is offline
2007 Ford F-250
redford has much to be proud ofredford has much to be proud ofredford has much to be proud ofredford has much to be proud ofredford has much to be proud ofredford has much to be proud ofredford has much to be proud ofredford has much to be proud ofredford has much to be proud of
I insert the nozzle all the way, then bring it out a bit before starting.
Also, if this is always the same station, try a different station and brand of fuel. Gasoline with a low Reid Vapor Pressure measurment can cause the nozzle to trip early due to heavy vapors.
__________________
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package 5.4L 3.73LS Tow Command
Stuart
Retired Master Sergeant
  #6 (permalink)
Old 11-11-2007, 10:00 AM
Biggziff's Avatar
Different stations, I've tried holding the handle in, out, up, sideways, you name it. If the truck is more than 1/2 full it doesn't do it.
__________________
2011 F350 CC 6.7
  #7 (permalink)
Old 11-11-2007, 10:09 AM
msgtg's Avatar
msgtg msgtg is offline
1992 Ford F-150
My Garage
msgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to behold
That's a common problem for most of us but normally its us diesel guys who have the issue. On the diesel side it's all about foaming.
On the gasser side it's usally due to a kink or bend in a line somewhere. Have you gotten up under the truck and taken a peek? The only time I've heard of thses kinds of issues are when there are kinks in the line to the tank.
__________________
03 F250 King Ranch Crew 6.0 4x4 92 F150 XLT SuperCab 4x2 03 Intruder Volusia 03 Ranger XLT
WV Chapter Lead JOIN THE WEST VIRGINIA CHAPTER CLICK HERE
We live in the Land Of The Free...BECAUSE of the Brave! My humble thanks to all Veterans, past and present
  #8 (permalink)
Old 11-12-2007, 07:34 AM
joeyj joeyj is offline
joeyj is starting off with a positive reputation.
i had the same problem with my 2005 5.4 s.d.,brought it in because no matter what way i held the nozzle,in, out ,upside down,it would take 20 minutes to fill up.At the dealer they said my overflow carbon vent cannister was plugged and they fixed it ,it now works great again.it worked fine when i got the truck and deteriated after time,still ok now.
  #9 (permalink)
Old 11-12-2007, 08:08 AM
Biggziff's Avatar
Quote:
Thanks..I'm going to check all the evap system to see if there is anything wrong there.
__________________
2011 F350 CC 6.7
  #10 (permalink)
Old 11-12-2007, 12:09 PM
RB_'05 V10 RB_'05 V10 is offline
RB_'05 V10 is starting off with a positive reputation.
I had the same thing on my 05 F250 CC SRW XLT V10. There is a TSB on this (http://www.ford-trucks.com/tsb/fullt...p?tsb=06-19-15) and when I had my truck in for something else, I took the TSB in to show them. They replaced the canister and seems to be fine since.
  #11 (permalink)
Old 11-14-2007, 05:12 PM
blackhat620's Avatar
blackhat620 blackhat620 is offline
blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.blackhat620 has a great reputation on FTE.
Here is the updated TSB on this,
TSB
07-23-13 SLOW FUEL FILL
Publication Date: November 12, 2007
FORD: 2005-2008 F-250, F-350
This article supersedes TSB 07-15-4 to update the Part List.
ISSUE:
Some 2005-2008 F-Super Duty 250/350 vehicles equipped with a 5.4L 3V or 6.8L 3V engine may experience premature automatic shut off of the fuel fill nozzle, or repeated fuel shut off at the fuel station delivery nozzle. Vehicles operated in muddy or dusty environments can encounter a dirt-clogged carbon canister system. More specifically, the carbon canister's vent, fresh-air box and filters become clogged with dirt from operating in such environments.
ACTION:
Use the following Service Procedure to resolve the concern if the carbon canister system is dirt clogged.
NOTE: THIS TSB ONLY APPLIES TO F-250/350 PICKUPS, AND F-250/350 PICKUP BOX DELETE/CHASSIS CAB VEHICLES
SERVICE PROCEDURE
Inspect the vehicle canister system and if it found to be dirt clogged then continue with this TSB.
NOTE: IF THE VEHICLE'S CANISTER SYSTEM IS NOT DIRT CLOGGED, THEN PROCEED WITH NORMAL DIAGNOSTICS AND DO NOT CONTINUE WITH THIS TSB.
Vehicles with Pickup Boxes:
Replace the carbon canister assembly with a canister built after 10/1/2006. This canister has a revised internal filter media, and went into production on 10/1/2006. The date code is on a black sticker located on the carbon canister assembly.
Relocate the fresh-air intake port to a more protected location using the fresh air hose kit, for pickup applications only.
Replace fuel cap assembly if the vehicle was built before 5/16/2007.
Vehicles with Pickup Box Removed or Chassis Cab:
Relocate the fresh-air intake port to a more protected location using QVM bulletin Q-132 at the body builder's website - https://www.fleet.ford.com/truckbbas/index.htm for fresh air intake routing recommendations.
PART NUMBER PART NAME
7C3Z-9049-A Fresh Air Kit - (MY 2005-2007)
8C3Z-9049-A Fresh Air Kit - (MY 2008)
6C3Z-9D653-F Carbon Canister - Pick Up (MY 2005-2007)
7C3Z-9D653-E Carbon Canister - Chassis Cab
8C3Z-9030-A Fuel Cap Assembly
7C3Z-9D653-A Carbon Canister - Pick Up (MY 2008 w/Midship Tank)
__________________
Courage is being scared to death---and saddling up anyway. -John Wayne-
06 F350 CC SB 6.0 4x4, Suburban Ford (Thanks Ernie )
“... there is no shame in not knowing. The problem arises when irrational thought and attendant behavior fill the vacuum left by ignorance.” ― Neil deGrasse Tyson
  #12 (permalink)
Old 11-24-2010, 05:32 PM
dontknow dontknow is offline
dontknow is starting off with a positive reputation.
i have replaced charcoal canester,filter,selonode andchecked fuel neck rtil cant get fuel to flow in (sorry i put this in to many times new user)
  #13 (permalink)
Old 11-24-2010, 05:35 PM
2003 f150 changed charcoal canester,filter,selonode and checked fuel neck still can only get to trical in
  #14 (permalink)
Old 11-24-2010, 06:03 PM
i have f150 2003 can only get fuel to trickel in changed charcoal canester,filter,selonode and checked fuel neck still no help???
  #15 (permalink)
Old 11-24-2010, 06:11 PM
same problem
2003 F150 changed charcoal canester,fiter,selonode and checked fuel neck still na o help
Tags
06, 07154, assembly, bypass, canister, carbon, clogged, f250, fill, ford, fuel, gas, tank, tsb, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
