i got a question...
Glad to see you've decided to follow the forum guidelines this go round
LP has been said to help burn off the extra fuel in the cylinders and real MPg have been somewhat disputeable. Not to mention the cost of the kit, cost of the tank, cost of filling the tank, and the gains have never really been enough for me to pull the trigger.
Cowboy Steve
Cowboy Steve
I played with this a few times with a setup I built myself.
I used a Hobbs pressure switch to open and close the propane valve off of a propane fuel fork lift.
I made an orifice and fumigation tube that I installed in the air intake to the air cleaner.
Use a two stage acetylene regulator to drop the pressure supplied from a BBQ tank.
I also had a master arm switch to shut everything down manually.
The cost as tested was under 100 dollars, but I did have most of the stuff I used laying around in my shop.
Hobbs switch from NAPA was 25 dollars.
Propane rated 12 volt solenoid valve was 50 dollars at the local LPG dealer.
Fuel rated hose, 1/4" copper tubing, brass fittings, wire, hose clamps and regulator were all from my shop.
Since any black smoke clears when the propane flows, the engine is more efficient at high throttle applications and does make more power.
Yes you can feel the propane kick in when the valve opens.
That was what I noticed at heavier propane fumigation levels.
Since this was a single level system it was more suitable as a power increaser, but I did not leave it in long enough to really tune it for smaller amounts of propane trying to increase the MPG.
My big problem was the BBQ tank made my dump bed usless, I needed the dump more than I need the propane.
Given the cost of fuel now, this may have to be given another chance though.
From what I have seen looking at prices, given the cost of a Manchester frame mounted tank and the remote fill (over 400 dollars) it would take a long time to see any savings from MPG increases.
Also the Power Shot 2000 system that varies the amount of propane flowing based on boost pressure would probably be the system needed to see any MPG increase and still be able to take advantage of the power increase unless you went with multiple Hobbs switches and regualtors or orifice sizes.
The Power Shot 2000 costs more (I found one for around 650 dollars) than the tank does, so now the cost is more than doubled.
And still to this day I am not sure, you may just be changing from diesel to propane for a fuel.
iwanaflattie
12-31-2011 06:15 AM
78bigunns
07-04-2002 05:22 PM
