You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Possible to replace timing belt without draining cooling system?
Just glancing through my Haynes manual, it says to remove the upper radiator hose and tstat housing. I haven't had a chance to look closesly at the engine yet, but is it at all possible to do it without draining the coolant?
__________________
1978 F100 For Play... SOLD! 501 stroker, ported Edelbrock Performer RPM heads, ported Performer RPM Air Gap, Comp Cams XE274H
1997 Ranger For Work... 2.3L/T5
1979 Honda CB750K
You can save and re-use the coolant in a drain pan. It doesn't have to be pitched.
You may want to filter it though - easiest way to do that is use a funnel to put it in a jug, then put a rag over the jug opening and tie a string around it.
This will strain it out while you pour it back in.
__________________
Think outside of the box - especially if you built it yourself
It's a lot easier to pull the radiator to work on getting the crank pully off...for that matter, I'm not sure a puller will fit in there at all with the radiator in the way so yes, you should drain the coolant. Shouldn't need to remove the T-stat housing though...
__________________
"alot" is not a word...
Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
I would try to get the pulley off first. It doesn't always need a puller, just a couple of long screwdrivers behind the pulley working it off. Then again, sometimes a sledge hammer won't get the thing to budge.
I just put a new belt on my Merkur. It took about an hour, and I didn't pull the radiator. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
Yes, the crank pulley has to come off to get the old timing belt off, and the new one on.
I've done the timing belts on both my BIL's Rangers, an '86 and a '93. It was very simple to pull the radiators on both, and it gives you a lot more room to work. I suppose I could have done it without pulling the radiator, but might have buggered it up in the process...
__________________
If you pull the radiator, and have A/C, put a piece of cardboard on the engine side of the condenser. Or thin plywood. If you have a Hulk moment, where something instantaneously comes loose while you were expecting it to stay seized in place, you will dent the cardboard rather than putting a hole in the tinfoil...
You will find it hard to get to one of the bolts without removing the thermostat housing. The crankshaft pulley may come off easily, or you may need a puller. If you live in Cleveland or similar, the rust will hold it on. You will need to loosen the tensioner boltS and then pry the tensioner to the release position, and, while holding it away from the belt, tighten the hold down bolt. Make sure it is at TDC when you start. The woodruff key in the crankshaft will be at 12:00 at TDC.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
Reason: spelling
