Build list for our trucks
1956 Ford F100
CHASSIS:
Frame: 56 Ford
Modifications: After market trans cross member, custom engine mounts, rear cross member moved to rear of frame and flipped 180 deg.
Rear End/Ratio : 1970’s Ford truck 9-inch, 3:50 ratio
Rear Suspension : Posie reversed eye super slide springs. Spring mounts moved up approx 2 inches and front ones flipped left to right. No Limit rear sway bar. Rear shocks moved outboard 2 inches per side.
Rear Brakes : Ford drum, 11".
Front Suspension : Volare, Fatman dropped spindles
Front Brakes : Stock Volare, Master cyl ,booster and brake pedal 1979 LTD11 Steering : Power Volare.
Front Wheels : 15 X 7 Steel with 4 inch back space, P215/70R15 W/W tires.
Rear Wheels : 15 x 8 Steel with 4 ½ back space, P235/70R15 W/W tires.
Fuel Tank : No Limit 17 gal aluminum tank mounted behind rear end.
Exhaust : Dual 2-1/2" dia steel tube with Flowmaster 3 chamber mufflers. Pipes exit at rear under fenders
ENGINE :
Year and Make : 1971 Ford
Displacement : 351W V8.
Camshaft : Edelbrock performer
Compression Ratio : ?
Heads : Stock 71 2 barrel 351W (for now).
Intake : Edelbrock Performer.
Exhaust : Stock 71 (for now)
Horsepower : No idea
Torque : No idea
Ignition : MSD
Air Cleaner : 15 X 3
Valve Covers : Stock painted Ford blue
Oil Pan : Ford Motorsports 351W / fox Mustang,
Radiator : 4 core from American Radiator, owner made fan shroud, stock 71 fan
TRANSMISSION : 1977 Ford AOD.
Shifter : Flaming River column shift.
Driveshaft : Custom made.
BODY : Body Style/Material: 1956 Ford F100
Body Mods : CPP front flip hood kit, shaved hood, 120 louvers in hood, shaved door handles, rounded door corners, filled cowl vent, filled exterior seams, filled gas filler, filled and smoothed steel gravel pan (also removed parking lamp mounts), no front bumper, third brake light, moved parking lamps to grill, rounded bottom of headlamps, removed V8 emblem.
Bed Mods : smooth tail gate, filled stake pockets, rounded lower end of stake posts, capped ends of bed rails, steel roll pan, custom taillight mounting brackets, plywood floor with custom fuel fill door, custom made storage box. sides coated with Line X.
Wiring : Ron Frances.
INTERIOR : Stock seat lowered ¾ inch, Vintage Air, Custom made dash extension for a/c vents, all interior seams filled, door edge modified to flow with dash, ash tray filled, power windows, pull style door handles, 70’s era Maverick door latches. B pillar modified to make latches look stock, flaming river tilt column, 1940 Ford style steering wheel, Autometer gauges, Some sterio system that never gets turned on, All new glass with a sliding rear window, It may get a interior next year and maybe some paint on the outside.
Yes I did copy Randy's form.
Chuck
CHASSIS:
Frame: 56 Ford
ENGINE :
Torque : No idea
Ignition : MSD
Chuck
CHASSIS:
Frame: 1956 Ford
Modifications: None
Rearend/Ratio: 1960 Ford 9", 3.50 gears
Rear Suspension: Rear hangers raised 1" Reverse eye main spring, Monroe shocks.
Front brakes: CCP disc conversion, 79 F150 rotors, GM Calipers, Mo-drop 3" drop axle, reverse eye main springs, steering stablizer.
Rear brakes: 1985 Cadillac Calipers, Cadillac rotors, Disc conversion.
Master Cylinder: 1995 Corvette dual disc.
Steering: Saginaw Steering box, manual, has plenty of bumpsteer.
Front wheel/tire: Boyd Coddington Smoothie II's 17X7, Kumho 225/50/17
Rear wheel/ tire: Boyd Coddington Smoothie II's 17X10, Kumho 255/55/17
Fuel tank: Rear mount aluminum CCP 19 Gallon, marine flush mount on bed.
ENGINE:
Year and Make: 1965 Ford
Displacement: 289 cu in. (girly motor)
Camshaft: Millings 480 lift - 283 duration.
Compression: 10.5:1 Flat tops
Heads: 65 Ford 289, ported polished, screw in studs, 351W springs.
Intake: Edelbrock ARM polished aluminum.
Carburation: Edelbrock 600 CFM (tweeked)
Ignition: Mallory dual point w/ pertronix, Mallory Super coil. Accel wires.
Headers/ Mufflers: Sanderson ceramic coated shorties, 2.5 inch pipes to Flowmaster 40 mufflers.
Valvecovers: Billet high tops.
Oil pan: Chrome Motorsport 5 quart
Radiator: 1960 ford F100
TRANSMISSION:
Year and Make: 1968 C4, Transgo shift kit, extra forward clutches.
Shifter: B&M Quick Silver ratchet shift. Floor mount.
Driveshaft: Stock
BODY
Modifications: Shaved hood emblems, door emblems, rear fenders extended 1.5" Smooth tailgate, Tucked bumpers front and rear.
Bed: Polished/varnished Oak wood, stainless strips. Side walls are Dupli color bedliner coating.
Paint: PPG Midnight Blue/ Corvette
Wiring: Home Depot multicolored
INTERIOR:
Dashboard: Stock gauges, speedo works.
Gauges: Stewart Warner Classic, Volts, Oil, Water temp. mounted in dash.
Steering column: BMW
Steering wheel: Billet/ woodgrain
Seats: Stock bench from 1954 F100
Carpet: All pro Interiors, low loop, Black w/ heel pads.
Door panels: Home made JoAnne's Fabrics, vinyl.
Headliner: ABS Mid Fifties, covered in Black suede. Visors are 40 Ford covered in Black suede.
Frame: 1956 Ford
Modifications: None
ENGINE:
TRANSMISSION:
Driveshaft: Stock
BODY
INTERIOR:
Build Sheet for "RMF100" aka "Euphemia"
1954 Ford F100
CHASSIS:
Frame manufacturer: 1954 Ford F100
Modifications:, boxed front & rear by me, engine mounts by me, tubular tranny mount. Rear rails notched for clearance
Rear-end/Ratio: 1972 Ford Mustang 9”
Rear suspension: stock with PVC liners, reversed eye main leaves, lowering shackles and alternate leaves removed.
Rear brakes: stock 1972 Mustang
Front suspension: 1984 “Volare” IFS stock
Front brakes: stock 84 “Volare” discs
Master cylinder: 1984 Chrysler 5th Ave. 1990 Ford F150 proportioning valve,
Steering: 1984 “Volare” with Adjustable power steering pressure control valve, custom made hoses by local tractor supply shop
Front wheel make, size: probably 17 X 7, probably salt flat discs
Front tire make, size: radials, probably 70 series to fill the wheel wells
Rear wheel make, size: probably 17 X 7, probably salt flat discs
Rear tire make, size: radials, probably 70 series to fill the wheel wells
Fuel tank: 1985 Chevy full sized van 18 gallon w/1985 fuel sender and mounting straps, chopper flush mount ,pop up, fuel filler neck in right rear fender
ENGINE:
Year and make: 1990 F150 Ford small block
Displacement: 5.0 liter bored 60 over
Camshaft: Comp Cam (for torque 1500 – 4500 rpm)
Compression ratio: stock
Heads: decked, ported and polished
Horsepower: maybe 250 hp
Torque: about 30 ft/lbs above stock
Manifold/Induction: stock Ford EFI
Ignition: stock ford
Headers/Mufflers: Mustang shorty headers
Air cleaner: none yet
Valve Covers: Plain polished aluminum tall units (for roller rockers)
Oil Pan: 1990 F150 rear sump pan and pick up tube
MISC: flow matched Bosch injectors, windage tray, Ford Motorsports roller rockers
Radiator: soon
TRANSMISSION:
Year and make: 1990 Ford AOD with Transgo shift kit
Shifter: on column
Driveshaft: 1990 F150 Aluminum , cut to length
BODY:
Body style/Material: Ford F100
Body manufacturer: Ford
Body mods: a few…..
Cab- chopped 3 inches. Rear roof seam filled. Gas filler on cab corner filled. Smoothed 57 F100 dash. Smoothed firewall. 1998 Ford Escort flush mount outer door handles, bear claw latches. Rounded front , top door frames.
Bed: 1994’ish GMC Sierra extended cab bed. Narrowed 16 inches. Outer 6 inches of 54 Ford fenders welded on. One inch taken out of front verticle section of fenders to pull down fender height. Wheel wells opened up about 2 inches. Wheel tubs removed from bed area and formed within bed walls. Gas filler door on front driver’s side filled. Upper and lower bed feature lines filled. Rear corners tucked in by about 1 inch. New inner bed walls made using bead roller. New roll pan hand made. “FORD” script welded into tailgate. Tailgate handle/latch moved to inside of tailgate. Tail lights filled and replaced with pairs of frenched 59 Cadillac units.
Rear bumpers are 70-73 Camaro RS front bumpers lengthened 4 inches. License plate lights are LEDs in the license plate bolts. Bed floor will be wood (likely Maple or Cherry) with chrome/SS bed strips.
HOOD: soon - mainly stock with hand made portholes and hand formed stainless trim. Hinges - undecided
Front Fenders: Soon (will be stock)
Grille: 54 F100 buckets with 54 Pontiac center section modified with flush mount LED signal light in the grille bar.
Front Bumpers: likely 70-73 Camaro RS front units lengthened about 8 inches each.
Bodywork: done by myself and oldest son – Ramsay.
Paint:Main cab is temporarily Black gloss but truck is mostly Epoxy primer covered with high fill primer darkened with black. Plan calls for two tone greens.
Wiring: almost none at this point.
INTERIOR:
Dashboard: 1957 Ford F100 filled and smoothed and welded in place of the original 54 unit.
Gauges: none yet, but lots….
Steering Wheel: none yet but either banjo style or 40’s art deco…
Brake Pedal assy: 1984 Chrysler 5th Ave.
Steering column: likely 1988-91 Jeep Cherokee with column shift.
Seats: likely 1988-1998 Chev/GMC pick up re-upolstered in tuck and roll with headrests removed
Carpet: someday
The plan calls for a SLIGHT old school or retro rod look. Not rat rod or in your face old school...
1954 Ford F100
CHASSIS:
ENGINE:
Radiator: soon
TRANSMISSION:
Shifter: on column
BODY:
Body mods: a few…..
INTERIOR:
Carpet: someday
OK This is what i have done so far:
CHASSIS:
Frame: 54 Ford F100
Rear End & Ratio: 1967 9" Detroit locker, 3:50 gears
Rear Suspension: 4 leaf stock springs
Rear Brakes: 11" drum
Front Suspension: 1979 Volare
Front Brakes: Volare disc
Steering: Volare
Front Wheels: To be determined
Rear Wheels: To be Determined
Fuel Tank: Aftermarket 20 Gal relocated to rear of frame.
ENGINE:
Year and Make: 1971 Ford
Displacement: 351W Bored 30 Over.
Compression Ratio:10.5:1 flat top pistons.
Camshaft: Comp Cams 268H Hyd
Heads: 1969 351W, Ported & polished and decked, Harlan sharp roller rockers.
Intake: Edelbrock EDL-7581 Air Gap intake, 600 Holley(for now)
Exhaust: Ceramic coated shorty's.
Ignition: Ford Duraspark(for now)
Valve Covers: Pro comp tall Aluminum.
Radiator: Stock i hope(Haven't had it gone thru yet)
TRANSMISSION: Ford C4
Shifter: Lokar floor shifter
Driveshaft: Custom made
BODY: Getting ready to work on it, Maybe some subtle mods but thats it.
INTERIOR: Mostly stock but I'm not there yet.
__________________
CHASSIS:
Frame: 54 Ford F100
Steering: Volare
ENGINE:
__________________
The more I think about it, I want to put mine on in it's "Expected" state. I've researched this for a couple years, and my mind is made up on most things. Besides, all the wife asks of me now is to buy furniture and other odds and ends, since we're almost all moved into the new house, and afterward, I can concentrate on my truck....even though it's winter. But, Bobby, I cut and pasted your build sheet, and will modify it to mine.
Ya know, to give ya something to laugh at.
As soon as the wife says I'm done moving for the day.
I guess I might as well post mine (copy of Bobby's). The problem I see with this thread is we cannot come back and update any changes. 6 months or a year from now..this will be all out of date.
Most of mine just says stock though!
1956 Ford F-100
CHASSIS:
Frame manufacturer: 1956 Ford,
Modifications: none
Rear-end/Ratio: stock/3.73
Rear brakes: stock w/polyliners
Front suspension: stock w/polyliners
Front brakes: stock
Master cylinder/booster: CPP underfloor kit and mid-fifty clutch linkage kit
Steering: stock
Front wheel make, size: 15” stock steel -- stock hub caps and chrome trim rings
Front tire make, size: Goodyear 215/75/15
Rear wheel make, size: 15” stock steel -- stock hub caps and chrome trim rings
Rear tire make, size: Goodyear 215/75/15
Fuel tank: stock 17 gallon behind the seat
ENGINE:
Year and make: Ford Y-block
Displacement: 272
Camshaft: stock
Compression ratio: 8.3:1
Heads: stock
Horsepower: 171 HP @ 4400 RPM
Torque: 260 ft. lbs. of Torque @ 2100-2400 RPM<O</O
Carburetor: Holly 2100 2 barrel
Ignition: stock
Headers/Mufflers: stock exhaust manifolds and exhaust crossover
Air cleaner: Round paper element (hate it!)
Valve Covers: stock
Oil Pan: stock
Radiator: stock
TRANSMISSION:
Make: ford 3 speed
Shifter: column shift
Driveshaft: stock
BODY:
Body style/Material: Stock F-100, steel
Body mods: none
Bed: stock
Horns: stock
Bodywork: solid, but needs work
Paint: not yet. Will be done will all SPI products.
Wiring: stock type (new replacement)
INTERIOR:
Dashboard: stock
Gauges: stock cluster and autometer gauges (on custom brackets)
Steering Wheel: stock
Brake Pedal assy: stock
Steering column: stock
Seats: stock (recovered)
Material/Color: black vinyl
Carpet: gray carpet and headliner
1956 Ford F-100
CHASSIS:
Modifications: none
Front brakes: stock
Steering: stock
ENGINE:
Displacement: 272
Camshaft: stock
Heads: stock
Ignition: stock
Valve Covers: stock
Oil Pan: stock
Radiator: stock
TRANSMISSION:
Make: ford 3 speed
Driveshaft: stock
BODY:
Body mods: none
Bed: stock
Horns: stock
INTERIOR:
Dashboard: stock
Originally Posted by eman92082
Hey Bobby....
I'll put this request on my "to do" list......
Change is not a problem, my list has changed alot over the years, I've just kept updating it as I go along. Now I'm wishing that I would have created a new build sheet everytime. That way I could have them as a sort of history of how things morped over the years.
Oh well, hindsight......
Bobby
#28
I think it may serve well for those under construction to copy to a text page on their computer and update as needed or can we do this in gallery so that it can be changed or updated there ?? I think this is a great would be great as part of profile so it can be viewed from any post in any forum with just a click like gallery. Just a thought
Jon
Jon
#29
Jon
Jon
I copied Bobby's list in this case, but it is almost the same list of stuff that is in my gallery.
#30
