11-09-2007, 07:46 AM
Thermostat Question
I have a 2000 Taurus 3.0 FFV. I recently changed my thermostat which I purchased from Ford. When I changed it, everything seemed to go smooth at least I thought. The Ford guy said the most common problem is not bleeding the air out of the system. I ran it until the thermostat opened with the coolant cap off, which is how I remember doing it years ago. After the install I had the coolant system flushed, good to go. Started it up on a cold morning, and drove about 10 miles before the gauge started moving. (Highway) In the city seems to run right in the middle where it should be. When I get on the highway it goes all the way down to cold. I figure the thermostat is staying open.
1. Is the thermostat installed correct? When I installed it was hard to keep it in place while trying to bolt the housing on.
2. Did I reverse the thermostat? I placed the core/spring inside the block.
3. When they flushed it, did air get into the system?
4. Defective thermostat?
