Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-09-2007, 07:46 AM
explorerford1999 is starting off with a positive reputation.
Question Thermostat Question
I have a 2000 Taurus 3.0 FFV. I recently changed my thermostat which I purchased from Ford. When I changed it, everything seemed to go smooth at least I thought. The Ford guy said the most common problem is not bleeding the air out of the system. I ran it until the thermostat opened with the coolant cap off, which is how I remember doing it years ago. After the install I had the coolant system flushed, good to go. Started it up on a cold morning, and drove about 10 miles before the gauge started moving. (Highway) In the city seems to run right in the middle where it should be. When I get on the highway it goes all the way down to cold. I figure the thermostat is staying open.
1. Is the thermostat installed correct? When I installed it was hard to keep it in place while trying to bolt the housing on.
2. Did I reverse the thermostat? I placed the core/spring inside the block.
3. When they flushed it, did air get into the system?
4. Defective thermostat?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-09-2007, 09:01 AM
I just took it on the highway for ten miles. The first five the temp gauge dropped right down to just above cold. Exit the highway, back to normal. Enter the highway and it goes down a little the first 2.5 miles, then down to cold.
  #3 (permalink)
Old 01-08-2008, 08:56 PM
mediaman67 is starting off with a positive reputation.
air trapped in system is my guess - you should be able to burp it fairly easily...
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
