Upfitter switch for High idle - Page 6 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
  #76
Old 10-25-2010, 05:52 AM
KC8QVO's Avatar
KC8QVO KC8QVO is offline
KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.
Not sure about any switched power under the dash, but there is a switched power wire going to the trailer plug. The guys at the dealer where I got my cap did that for the lights... As soon as I got a chance I wired them to a switch on the dash (not an upfitter, home brew jobby but does the same thing - lots of other stuff on the panel besides the on/off switches though).
On a side note, I just started reading this thread and realized it was an old one from 07. Anyway, theres a post on the first page talking about how there is a buit-in ide up feature if you idle longer than 120 seconds when cold or something. Mine does this all the time in the morning. The RPM's go up over 1000 when this happens. If it happens automatically, why put a switch in for it? Maybe I don't let mine idle long enough to see it drop back down but it does kick the RPM's up after a short time when I first start it.
  #77
Old 10-25-2010, 06:15 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
If you plan to park for 30 mins to eat lunch and need the a/c running, then its best to idle up .. have to control this manually..
lots of other reasons..
Sam
  #78
Old 10-25-2010, 10:18 AM
fg250's Avatar
fg250 fg250 is offline
fg250 is starting off with a positive reputation.
yeah, it only does that when it's cold, once warmed up it won't do it.
  #79
Old 10-27-2010, 02:45 PM
seanjackmc seanjackmc is offline
seanjackmc is starting off with a positive reputation.
so I just hooked up the wires as described on here and everything works great. Is it ok to just twist the wires together then wrap with elec tape? I figure there isnt much draw on the connection so I should be ok??? Let me know if not. By the way will the truck warm up faster now that this is done on those cold mornings and can it idle now for however long I want it to with out concern of wet stacking?
Thanks for the help
STM
  #80
Old 10-27-2010, 03:13 PM
sdetweil's Avatar
you should at least use a screw on cap, and some dialectric grease to keep the connections clean.. tape by itself usually isn't good for temp, movement, etc..
this will over-ride the auto SEIC, so it should be ok.
Sam
  #81
Old 10-28-2010, 02:30 PM
ab257z ab257z is offline
ab257z is starting off with a positive reputation.
Also, if you have a turbo cool-down timer on your shutdown (third party security system), the high idle comes in handy.
  #82
Old 11-24-2010, 04:28 PM
koboss1's Avatar
koboss1 koboss1 is offline
koboss1 is starting off with a positive reputation.
I need help I hooked these 2 wires up tonight with a heat shrink connector
Put E brake on, in P, started and turned on #4 uppfitter and nothin happened
Also checked the fuses on the passenger side and it was fine ?? HELP what am I missing
  #83
Old 11-27-2010, 06:08 PM
IHbase's Avatar
IHbase IHbase is offline
IHbase has a good reputation on FTE.IHbase has a good reputation on FTE.
Or you could just shut the damn thing off. It is not 1950 and you are not running a Cat.
-mike
  #84
Old 11-27-2010, 06:21 PM
LaxPlaya21's Avatar
LaxPlaya21 LaxPlaya21 is offline
LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.LaxPlaya21 has a very good reputation on FTE.
Quote:
-mike
Hahha come on... there are def pleny of reason to idle.
  #85
Old 09-07-2011, 12:01 PM
AKPostal AKPostal is offline
AKPostal is starting off with a positive reputation.
Quote:
Originally Posted by DieselWhisperer View Post
It's easier than you think, I did mine a couple of days ago. Just pop off the plastic cover under the steering wheel, find the green/yellow wire in the large bundle of wires just above the Ebrake (they are bundled together and all have a black heat shrink looking end on them) then right above that bundle you'll see another group of 4 wires, I forgot the colors, but there is a solid brown one in that group (the brown one is for upfitter switch #4). Just make a jumper wire about 3 or 4 inches long and connect the green/yellow to the brown wire. It works! The E-brake has to be set and the transmission in PARK. Mine revs up to about 1200 RPM. If you touch the brake pedal, it will cancell it out.
Ok I just hooked mine up and it does have power through it when I hit the Up-fitter Switch. It does not do the high idle. Does the engine have to warm up first? I do have an auto start that has turbo mod. So when u press the e-brake it will stay on for 2 minutes. Is there anything under the hood I need to hook up?
OH I AM IN ALASKA SO I DO NEED THIS MOD!! IT GETS -50 HERE!!!!! PLEASE HELP!!!!
  #86
Old 09-07-2011, 07:03 PM
Yellow Wire with Green Stripe works great!!!LOL
  #87
Old 09-13-2012, 11:06 AM
hinesks hinesks is offline
hinesks is starting off with a positive reputation.
Hooked mine up yesterday and it works great. 1200 rpm everytime.
  #88
Old 11-25-2013, 10:21 PM
phudgins phudgins is offline
phudgins is starting off with a positive reputation.
Quote:
Originally Posted by alchymist View Post
PM me with an email address and I'll email you the Service bulletins I have (Q files, PDF format). Anyone else wanting them feel free also.....
I could sure use the idle info! Thanks, phudgins25@gmail.com
  #89
Old 01-11-2014, 02:24 PM
KR250's Avatar
KR250 KR250 is offline
KR250 is starting off with a positive reputation.
I know this is an old thread, but I am new to the site and new to Diesel engines! I just bought a 2010 King Ranch F250 6.4L and I found this site while trying to familiarize myself with this engine. There is a lot of good info on this site!
I hooked up the high idle to Aux 4 and it works great. Just curious when you guys use it though. I sometimes park for extended periods during duck season in Florida, and I pictured using it to the run the A/C while parked/sleeping in the truck. BUT...should I run it at high idle continuously for hours, or intermittently throughout the night? Thx. for the info.
SEIC High Idle Upfitter Switch Uzumati 2017 Super Duty 104 03-11-2017 06:34 PM
Are upfitter switches powered when truck is remote started? 90pioneer 6.7L Power Stroke Diesel 4 11-02-2015 11:48 AM
2 days research-can't figure it out sgrol 6.7L Power Stroke Diesel 6 11-02-2014 06:37 PM
High idle mod without upfitters? ROBBINthaHOOD 6.0L Power Stroke Diesel 15 04-01-2014 08:52 PM
High idle mod i eat hybrids 6.0L Power Stroke Diesel 21 04-19-2010 07:48 AM
Tags
2005, 2008, 64, ambulance, bcp, f250, f350, ford, high, idle, mod, powerstroke, seic, transmission, van, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
