Upfitter switch for High idle - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 03-28-2008, 10:52 AM
ab257z ab257z is offline
ab257z is starting off with a positive reputation.
I know - I do the same thing about snapping off tabs. But the tabs look pretty sturdy compared with other cars - they all have inserts. I started at the lower left and lifted up - not at the top and pull down. the tabs are mounted on the removable piede and are slanted down.
Old 03-28-2008, 08:38 PM
big kahuna's Avatar
big kahuna big kahuna is offline
big kahuna is starting off with a positive reputation.
It come right off with very small amount of force ! Pops back on same .
Old 03-29-2008, 01:34 PM
Quote:
Originally Posted by bookem15
Does anyone know if the dealer will hook up the high idle and also can you leave the switch on at night then remote start the truck in the am and have it go to high idle automatically??
Don't know about the dealer (don't see why not), but with my Compustar you can remote start it in high idle (it ramps up a couple of seconds after starting).
Old 09-08-2008, 09:46 PM
1984F-150_351HO's Avatar
1984F-150_351HO 1984F-150_351HO is offline
1984F-150_351HO is starting off with a positive reputation.
Stick shift PSD 6.4 PTO mode?
I use my truck quite a bit for jump starting junk cars to get them up on the car hauler, or on rare occasion I have to jump my big truck as it usually sits for long durations of time. On the small cars it does fine with having the duel alternators and duel batteries; however when I try to jump my rig it takes at least 45min to an hour. I'd really like to hook up the high idle mod to my truck, but I wasn't sure if I'd run into a problem with my truck having a 6 speed stick. I'd appreciate an answer at your earliest conveniences. Thanks a bunch.
Old 11-02-2008, 02:11 AM
hammer toe hammer toe is offline
hammer toe is starting off with a positive reputation.
my dealer didn't know how to do this. high idle set up.
Old 11-02-2008, 10:17 AM
Pto
Don't see why high idle would be any different on a stick. It uses the power take off electrical system. The wiring diagram doesn't show any difference between the auto and manual
https://www.fleet.ford.com/truckbbas/non-html/Q162.pdf
The Econolines have a different color, but the trucks are yellow/green for both gas and diesel.
Old 12-09-2008, 08:41 PM
Super08's Avatar
Super08 Super08 is offline
Super08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to behold
Something with the 08's and 09's with the heavy duty or dual alternators is it only revs up to 900 instead of 1200 when hooking up to the BCP wire. I thought I hooked to the wrong wire, but I seen others had the same problem on their trucks. I am going to add a 10k resistor and see what that puts me at.
Old 12-10-2008, 12:21 PM
mikey2000 mikey2000 is offline
mikey2000 is starting off with a positive reputation.
Quote:
I have dual alts and it idles at 1200. You sure you got the right wires? I think green/yellow is the SEIC wire and brown is the #4 upfitter switch.
Old 12-10-2008, 04:13 PM
stevestroke01's Avatar
stevestroke01 stevestroke01 is offline
stevestroke01 is starting off with a positive reputation.
When I first hooked mine up in July I used the BCP wire and upfitter switch #3 and it would only idle up to 900 also. I thought the same as you about possibly hooking up the wrong wire until about a month ago I fired up the truck when it was about 30 degrees F out and flipped the switch and it idled up to 1200 just like my 6.0 did all the time. So I don't know what was different other than the outside temps. Mine also has the heavy duty alternator. Would like to hear some opions or answers if anyone has any... Thanks Steve
Old 12-10-2008, 07:32 PM
SANDDEMON08's Avatar
SANDDEMON08 SANDDEMON08 is offline
SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.SANDDEMON08 has a great reputation on FTE.
I have never had a poblem with mine 1200 every time. I know you have to be in park or neutral and have the parking brake for the seic to activate.
Old 12-11-2008, 10:26 AM
Nipperdog's Avatar
Nipperdog Nipperdog is offline
Nipperdog is gaining momentum as a positive member of FTE.
Quote:
I hooked mine to the #3 switch and it always goes up to 1200. I use the hi idle primarily to run the AC for extended periods in the summer. I don't think it would matter which switch you wire into as long as the seic circuit sees 12volts
Old 12-12-2008, 11:46 AM
fomocotrucks fomocotrucks is offline
fomocotrucks is starting off with a positive reputation.
With the BCP mod, mine also only idles at 900rpm. I have put a load on the batteries and the BCP circuit is working as the rpm's increase with load.
  #28
Old 12-23-2008, 09:42 PM
Black MI's Avatar
Black MI Black MI is offline
Black MI is starting off with a positive reputation.
Quote:
Mine has the dual alternators and will idle at 1,200 (or lower) depending on the electrical system demand. The intent is also to provide charge to the batteries; if the system is low, the idle will accomodate and idle at a higher rate. My 2006 6.0L was the same.
You will find that the engine will increase idle in this mode depending on the load. With travel trailer connected, increase the demand on the electrical system by powering the electric jacks, or the push-outs -- watch the RPM's respond accordingly to meet demand.
  #29
Old 12-24-2008, 11:02 AM
caprang's Avatar
caprang caprang is offline
caprang is gaining momentum as a positive member of FTE.
Im a bit confused on the difference between going through the SEIC wire (yellow/green) or the BCP wire (color not mentioned). Whats the difference? Which is better?
  #30
Old 12-24-2008, 06:15 PM
One works of charge condition and the other works for a pto function. The BCP works of voltage, and the other wire works of a preset resitance. You have to put a resistor in to match the rpm range you want. Or you can put a reostate in and have a variable rpm ramp.
SEIC High Idle Upfitter Switch Uzumati 2017 Super Duty 104 03-11-2017 06:34 PM
2 days research-can't figure it out sgrol 6.7L Power Stroke Diesel 6 11-02-2014 06:37 PM
High idle mod without upfitters? ROBBINthaHOOD 6.0L Power Stroke Diesel 15 04-01-2014 08:52 PM
2010 F350 SD Upfitter switches gone campin 1999 to 2016 Super Duty 6 08-31-2010 04:03 AM
High Idle without upfitter??? jlindsay1150 6.0L Power Stroke Diesel 11 11-15-2009 04:16 PM
Tags
2005, 2008, 64, ambulance, bcp, f250, f350, ford, high, idle, mod, powerstroke, seic, transmission, van, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
