air pump delete
I just went to the autoparts store and got a bunch of belts and tried them till one fit and took the rest back.
Make sure you cap all the lines that will be exposed. It's a pain in the butt to get them all capped... lines that look like they go nowhere connect to EVERYTHING eventually.
it wasn't until I had my motor out of the truck a year later that I discovered how insane the system was. With everything removed it actually looks like an engine bay, though...
Here's the link.......not too bad a price either... http://store.summitracing.com/partde...0&autoview=sku
Justin,
I just used a shorter belt, length determined by a piece of string routed around the pulleys, then subtracted 2" to allow the tensioner to have some belt length to push against.
It's been that way for years no problems, though without the air pump installing new belts is a bit snug.
mine actually came with a shorter belt and no pulley on the air pump. The pump turned fine so i got a new pulley from a junk yard ($5) got longer belt and replaced the air check valve. now it runs smoother and feels like it has more power the cruise holds at speed a lot better and i actually gained 2 mpg.
I'm not trying to start trouble, but it's illegal to tamper with pollution equipment. I would think as a moderator you would know better than to post a thread about doing something like that. There are a lot of people on here that advise people about how to remove such equipment, unfortunatly a lot of these younger members heed that advice. Ford fuel injection systems were designed to work with all the components in good working order. I doubt that removing the air pump is going to give you a great performance boost anyway. Like I said I'm not trying to start any trouble. Thanks, Robert.
If you read into laws at all, mayb you would be a moderator, but this is exactly why MustangGT is one, and why your not =]
While you're correct that the Ford EEC is designed to run the truck with all the pollution do-dads intact and functional, I have none of them on my 93 crewcab (they're there, just not functional) and my truck pollutes less than it did BEFORE I disabled them.
Why?
I got rid of the old technology catalytic converter, and installed a new, generic one.
ford racing makes them too. the bracket looks just like whats on my 96 351 from the factory (obd2) no air pump
http://www.fordracingparts.com/parts...tKeyField=2203
Originally Posted by NeXtras
Most of these generation trucks will pass emisions without a catalytic. Ive thought of having mine hollowed out, or just put a magnaflow highflow catalytic. They vissualy inspect for a catalytic here in MA so I need to use one of these two options. I'm still using the factory catalytic which is almost 13 years old now.
And my truck won't pass without the cat - but I'm above 450k in mileage so that's totally understandable.
