Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Pennsylvania Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Pennsylvania Chapter Join Chapter, Leader: Oldtrucknut7077
  #1 (permalink)
Old 11-08-2007, 03:03 PM
cjg1999 cjg1999 is offline
Garage is empty, add now
cjg1999 is starting off with a positive reputation.
Differential - Gear Swap
Anyone know of a good (reasonably priced) shop to swap ring and pinions in the philly suburbs?
  #2 (permalink)
Old 11-08-2007, 07:47 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.c00nhunterjoe has a very good reputation on FTE.
can you do it yourself? it would be much cheaper
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
  #3 (permalink)
Old 11-09-2007, 07:54 AM
Quote:
the rear yes, but i have never tackled the front diff before.
  #4 (permalink)
Old 11-09-2007, 01:11 PM
soondg's Avatar
soondg soondg is offline
Peek a boo poster
soondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud ofsoondg has much to be proud of
cj, sent you a PM. give me a call.
__________________
Joe
STUFF IS COOL-TORQUE PULLS MORE STUFF- TORQUE IS COOL
Pennsylvania Chapter, Home of the Mid Atlantic Meet JOIN US HERE!
  #5 (permalink)
Old 11-09-2007, 09:30 PM
the front is no different from the rear, its just in backwards thats all
__________________
  #6 (permalink)
Old 11-10-2007, 10:19 AM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
rears can be tricky . I have done but things do go wrong. Good luck
__________________
Red Neck rule #1 If you drive a truck you should always be looking for trucks to get parts off of. If you can't find part used you aren't looking hard enough.
94 F150 XLT 4x4 SC LB MAF 302 E4od 3:55 ls rear
MSD blaster coil ,cap rotor ,Fordracing 9mm wires
Tags
differential, ford, gear, gears, pennsylvania, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
