You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Ok guys I just finished this post for another site and figured I would throw it over here so you could enjoy it as well.......
This is my Bio processor that was built from scratch. I pulled bits and pieces of ideas from others on many sites to put it all together.
This system will process 40 gallons per day with a capacity of 120 gallons in progress at any one time.
Here is a shot of the entire setup. The closest barrel is the cone bottom processor. The middle barrel is a continuous mist wash and the far barrel is the dry tank.
The processor tank itself is a 55 gallon drum that had the solid bottom cut out and a cone base added. This processor is heated by a 4500 watt water heater element that is controlled by a water heater t-stat.
The methoxide is mixed in 5 gallon jugs and then introduced into the processor through a quick connect fitting.
The wash tank is set up for a continuous wash. Usually I will turn on the wash on my way to work in the morning and then I have a washed batch when I get home.
Here is a shot of the mist head in action......
The dry tank is set up for heating similar to the processor. I pump the fuel across a 4500 watt element and then it is sprayed out through the top PVC pipe with the fan blowing across it. I usually run the temp up to about 160F. Humidity plays a big roll in how fast I can dry a batch. I have dried 40 gallons in as little as 45 min and I have had batches take up to 3 or 4 hrs.
Here are a couple pics of the drying process. Notice the color change from the wet to dry shots.
Wet...
Dry....
Here is a shot of our lab table with the titration supplies on it....
My finished fuel is stored in metal 55 gallon drums under a vacuum seal. I have found that if I run the fuel into the drum right when it finishes the dry process and it is still hot it will draw a nice vacuum on the drum as it cools.
I noticed the open wood beams. You might want to add sheetrock to the ceiling.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Like my wife would ever allow something THAT FUN TO RUN near our home!
You should offer detailed pictures of every section with arrows pointing out everything with part numbers included (only for non stock items like that blue pump and the square silver thing (heater?) on the drum side, not the simple things like pipe fittings) and a full set of assembly and operation instructions!
Most pictures on line do not seem as nice, detailed or as clear as yours, and it look like there is a minimum of high dollar (got to buy it only from me) parts.
With just a little extra effort you could rake in some extra $$$ for something you have already done!
The pumps are from Northern Tool. DO NOT GET the pumps from Harbor Freight. They look the same but are not as powerful. The silver boxes are simply an electrical box that is spot welded to the drum. It houses a water heater thermostat that controls the water heater element. If you follow the wire from the electrical box you can see where it attaches to the bottom of the 1" "T" that is the bottom of the water heater element. I am working on some better pictures that are labeled and will post up when I get them done.
I would also like to make this system. Please pm or post some more info. Thanks
Kyle
__________________
04 crew cab 6.0 4x4
train horns
SCT XCAL2 from Matt @ Spartan
remote start
5" lift with 35's
traction bars
4" MBRP turbo back straight piped to 6" single stack
some other pullin goodies
__________________ WANTED: Someone to go back in time with me. You'll get
paid after we getback. Must bring your own weapons.
Safety not guaranteed. I have only done this once before. www.jimkidd.com
