78-79 ford help
78-79 ford help
Hi guys i am looking to buy a 78/79 ford and i have run nto a few questions along the way. by the way i am interested in 4x4 models only. First what is the dieffernce between the f100, 150, and 250? and the option like explorer, custom, ranger? I would really like to get a reg cab and am looking to lift it using the CAGE offroad 4" lift. This lift works with the front coil spring setup but i know some trucks had leaf springs up front. which setup would you recommend for a tough trail truck/daily driver. Also if i went the way of the coil spring front setup i would like to drop a dana 60 front diff. in. i heard there was a kit to make the diff work with coil springs/radius arms? any help or links to the informatin would be greatly appreciated, i'd like to do things right the first time. Thanks
Hello, the best advice on the site is to do a search for each question. These things have been covered several times in great depth. All these trucks are tough. The easiest way to get a d60 in front is to buy a 250 with one or all 350s came with them. 79 is the first year for 4x4 f350. All 250/350s came leafs in front. 100/150 4x4s had coils. Mods. for the truck are based on your abilities, fundsand use of the truck. These things are not cheap once you get one. Everyone here will agree on that. Always room for improvement, and always room in the gas tank.
Welcome to the site
Please don't be afraid to make one thread per topic and title that thread with thre topic in it.
You have so many questions in one thread it will take some time to sort out.
Basically F100,F150,F250,F350 are just GVWR or weight related models.
They all share the same body and trim
Custom,Explorer,XLT,Lariat are TRIM LINES.
With a Custom being a truck you could build anyway you want.
Explorer was a special marleting trim line
XLT was standard Luxury Trim Line
Lariat beginning in 78 became an even more Standard Luxury Model .
You can read about them on my website here.
http://www.clubfte.com/users/mil1ion...urePhotos.html
and 79 brochure here.
http://www.tocmp.com/brochures/Ford-...ure/index.html
on
1 Post
gittinwidit
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
08-02-2006 09:03 AM
Rediranch_too
05-05-2004 04:22 PM
