You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I tried to thread jack in another posting, but it didn't work. I am trying to install a high level to low level (speaker wire to RCA) converter so I can hook up my bass shakers in my seats but I need the color breakdown on the back of the head unit so I can splice into it correctly. If someone has the maintenance DVD and can post the colors up, it would be much appreciated. I have the 6disc MP3 changer with sirius radio, no sub woofer. I pull back in to port in a few days and would like to do it then.
FYI, the stereo is VERY easy to access. That trim around the control area is just a snap in piece. Get a panel puller, it pops right out, or you can use a screw driver but be careful to not scratch the plastic. There is enough slack on all the cables that you do not have to disconnect anything. Then its just 4 bolts holding the radio in. Piece of cake. Should take the average person less than 5 minutes to do. There is tons of space in there as well for those who want to add an aftermarket setup with say a blue tooth adapter, HD radio receiver and so on...
Panel pullers can be bought at local auto parts store for 5-10 bucks. They are sometimes found in the rack of "HELP" stuff. Usually a shaped piece of metal with the correct shape for popping the plastic push nuts off. The better one have nice handles-I have cheap and expensive both work well.
My panel puller is a bit different, but was found in the help isle. It does everything, headlight adjustment, door **** clips, windshield clips and so on. It was 7.99 I think. But thanks for the wiring breakdown, I will post some pics when I open it up tomorrow after get home, a very very short how to.
Thanks, it was almost exactly right, the front left was a bit different, but they were smart enough to electrical tape together the associated pairs, so it wasn't too bad. Thanks again for the starting point.
DOES ANYONE HAVE THE WIRING SCHEMATIC FOR OVERHEAD DVD IN A 07 EXPEDITION.BOUGHT ONE OFF EBAY.GOING TO PUT IN 06 CREW F250.ALL HELP WOULD BE APRECIATED. shwn_jackson@yahoo.com
