bad ignition module symptoms? - Ford Truck Enthusiasts Forums
Old 11-07-2007, 02:43 PM
fordinmudd's Avatar
fordinmudd fordinmudd is offline
fordinmudd is starting off with a positive reputation.
do ignition modules act up and have symptoms when there starting to go bad?or do they just die and thats it?
Old 11-07-2007, 04:42 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
The most common partial failure is heat related. You will be driving along and it will quit. After it cools off, will run again till it warms up and quits again. Otherwise, it usually is dead and won't do anything at anytime.
Old 11-07-2007, 08:40 PM
blue beast's Avatar
blue beast blue beast is offline
blue beast has a good reputation on FTE.blue beast has a good reputation on FTE.
Carrying a can of keyboard duster and holding it upside down and blasting the module
will get you off the side of the road quicker if it fails due to heat failure!! Just try 20
seconds or so to start and see if it cranks back up. It also works for coils and other
electrical components and even fuel line heat(vapor lock) problems. So keep a half
empty can in your truck and wait 7 minutes instead of waiting an hour for it to cool!!
I super glued a heatsink to the back of mine and ran a intake tube to the distributor
area to get a blast of cold air from the radiator support blowing on to it.
Old 11-13-2007, 04:13 PM
PerfDistIgnition PerfDistIgnition is online now
FTE Sponsor
PerfDistIgnition is starting off with a positive reputation.
Quote:
Sometimes they can cause your timing mark to jump around very erratically, 6 to 10 degrees.
http://www.PerformanceDistributors.com
__________________
FTE Sponsor
Performance Distributors
Symptoms of bad TFI module? MustangGT221 1987 - 1996 F150 & Larger F-Series Trucks 28 08-14-2016 09:22 AM
Ignition Control Module Glenn.b1 1987 - 1996 F150 & Larger F-Series Trucks 13 05-09-2015 02:05 PM
Duraspark ll ignition module? Whats its exact funtion? Superdave 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 42 11-21-2010 02:00 PM
Duraspark II swap. wont start jmc0369 Ford Inline Six, 200, 250, 4.9L / 300 10 10-01-2010 06:56 AM
Ignition Module question FordLuvinJarhead Electrical Systems/Wiring 4 07-01-2003 09:45 AM
Tags
1990, 2007, bad, coil, control, f150, f350, failure, ford, gt, igniter, ignition, module, probe, signs, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
