Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > New York Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
New York Chapter Join Chapter, Leader: tiny1
  #1 (permalink)
Old 11-07-2007, 02:41 PM
runitsdafuzz runitsdafuzz is offline
Garage is empty, add now
runitsdafuzz is starting off with a positive reputation.
I Really Need Help!!!!!
this might sound like an odd question but does anyone in the rochester/chili area willing to come look at my truck and possibly help me fix it im only 17 dont know very much but willing to learn as much as i can. thanks
  #2 (permalink)
Old 11-07-2007, 04:03 PM
tewferford's Avatar
tewferford tewferford is offline
tewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant future
Quote:
Why don't you tell us the problem you are having, and hopefully we can point you in the right direction.
year
FI/carb
motor
model
And anyting else we need to know.
__________________
Frank
I live in my own little world,but it's OK, they know me here.
Chances are,If you bought it, A truck brought it.
  #3 (permalink)
Old 11-07-2007, 04:59 PM
1990 f250 fuel injected i was told its a 351 windsor havent checked the numbers yet, i have smoke comen out of the valve cover when its being revved or when im driving smoke pours out at about 2700 and up but when im in about 4th and 5th it kinda calms down cause of low rpms i was told multiple things like its the rings valves and some other stuff and i dont have a lot of money, i was going to do a compression test but couldnt because of weather and not having a big enough garage to work in and the fact it doesnt run because of possibly the alternator so weather hasnt been on my side and now i dont have a compression tester because it belongs to my teacher and i had to give it back.....so idk what to do anymore.
  #4 (permalink)
Old 11-07-2007, 05:40 PM
tewferford's Avatar
No smoke coming from the exaust????? just from the motor?
__________________
Frank
  #5 (permalink)
Old 11-08-2007, 04:11 AM
freevilleron freevilleron is offline
freevilleron is starting off with a positive reputation.
sounds like its building pressure possible cause could be pvc could be plugged or vent tube drain ports in head could be plugged or sticking oil rings
  #6 (permalink)
Old 11-08-2007, 07:49 AM
tewferford's Avatar
Quote:
Yeah I agree, hence the question of where the smoke is coming from.
__________________
Frank
  #7 (permalink)
Old 11-08-2007, 04:49 PM
smoke comes out of the exhaust and the valve covers i change the pcv(positive crankcase ventilation) valve when i got it.
  #8 (permalink)
Old 11-08-2007, 05:07 PM
tewferford's Avatar
You will have to do a compression test. It don't sound good tho.
__________________
Frank
  #9 (permalink)
Old 11-08-2007, 05:15 PM
have you checked the plugs to find out what cylinder is doing it
  #10 (permalink)
Old 11-08-2007, 05:23 PM
Greywolf's Avatar
Greywolf Greywolf is offline
WILD CARD
1989 Ford Ranger
Greywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputationGreywolf has a superb reputation
1) Go for the PCV valve idea first. It is rightly called the Positive Crankcase Ventilation Valve, and is there because some blow-by past the piston rings can happen, and it controls the buildup inside the engine by evacuating it to the intake manifold - right about when you have hi vaccuum, such as at sustained highway speeds. They often plug up with gunk over time.
2) Do the compression test as soon as possible, because you definitely have some blow-by, the question is HOW MUCH.
3) Take a look at your air filter. It could provide an indication of how much blow by has happened over time. They don't just fail overnight. If it's black with crud, it's a good time to spring for another one. To some degree they are cleanable, you'll have to see it to judge. May I suggest carb cleaner, compressed air, gloves, goggles, and the great outdoors... (It'll make a mess) *DON'T use gasoline.
4) If you are planning an oil change, you can try ONE pint of diesel in the oil before it is changed, run it for ten or twenty minutes, then drain it out well. This may flush most of the crud out of your engine, but if you do this - a new oil filter is a MUST HAVE, because it will be filled up with it all.
Old timers will tell you - DIESEL FUEL will clean out an engine better than ninety nine percent of what is sold in parts stores for three times as much money. I believe it is true. But you can't run it in there for very long. Twenty minutes tops, followed by a complete drain.
It may also have a long lasting effect in an engine that has been severely abused. In the valley area under the intake manifold - there is often a thick layer of built up crud that can only be loosened up gradually. You can't see it without removing the intake, so watch your OIL COLOR if you try this, for a while afterward. It could increase your need to replace the filter and oil if there really is a HUGE bunch of stuff in there.
But you might still save the engine!
I am not one to recommend "QUACK" strategies, by the way. Ask around about this, and see what others here say about it.
__________________
Think outside of the box - especially if you built it yourself
  #11 (permalink)
Old 11-09-2007, 03:36 AM
i was going to suggest this to but i figured someone would say something bad about it but this does work i have done it to one of my trucks
  #12 (permalink)
Old 11-09-2007, 04:22 AM
lenny1carl's Avatar
lenny1carl lenny1carl is offline
lenny1carl has a superb reputationlenny1carl has a superb reputationlenny1carl has a superb reputationlenny1carl has a superb reputationlenny1carl has a superb reputationlenny1carl has a superb reputationlenny1carl has a superb reputationlenny1carl has a superb reputationlenny1carl has a superb reputationlenny1carl has a superb reputationlenny1carl has a superb reputation
my advice(not being a big motor head) is put the question to the guys in the 87-96 f150 and bigger section. those guys have bailed me out many times. the advice you've gotten here sounds good.. those guys will go into a ton of detail.
damn near an e-engine tear down
__________________
carl,sassy & Nancy(R.I.P. babe, we miss you. 5yrs now, no less hurt)
NY problem solver dammit. R.I.P. Dono
  #13 (permalink)
Old 12-19-2007, 07:25 PM
rsylvstr rsylvstr is offline
rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.rsylvstr has a very good reputation on FTE.
ANY UPDATES?
__________________
Master Chief, HMCM(FMF/AW)
JOIN US http://www.nyfirearms.com/forums/ind...eferrerid=1780
The best battlefield medicine is fire superiority
2001 SCrew Lariat 4x4 5.4L 4R70W 3.55 's LS
Cooper ATR's, K&N Series 77 CAI
  #14 (permalink)
Old 12-19-2007, 07:38 PM
Greywolf's Avatar
WILD CARD
1989 Ford Ranger
None - I don't even know where the guy is AT.
__________________
  #15 (permalink)
Old 12-23-2007, 12:56 PM
Ronin007's Avatar
Ronin007 Ronin007 is offline
Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.
He hasn't been on FTE since 12-03-2007 at 09:07 PM so don't know if got his truck fixed or not.
__________________
Darren
1999 F-350 Super Duty XLT 4x4 V10 extended cab
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
