body mounts
body mounts
Does anybody know where I can get all new body and radiator support mounting hardware for a '78 F250. I need the rubber/poly bushings as well as the two metal bolt pieces. I had to cut off all my body and radiator mounts with the blue wrench because of severe rust.
Does Bronco graveyard, BOTP or Dennis Carpenter have these?
Thanks,
Eric
Thanks,
Eric
Thanks,
Eric
Thanks,
Eric
Originally Posted by bucks77ford
The only thing that you can't get is the upper mounting sleeve for the radiator support. Everything else you can get through those places you just mentioned. Plus National Parts Depot or Auto Krafters in addition.
D3TZ-1000396-C .. Absorber and Sleeve ~ I just typed this number into y2kfordparts online parts locator. The locator sez: No parts found = obsolete.
FTE sponsor GREEN SALES doesn't have it either.
Despite what the fellow said about, not all the parts are still available from Ford.
Originally Posted by hp246
I bought all six pairs of mounts, not including the bushings from my Ford dealer last summer. They had to go to the old microfilm, pull the numbers, then go to the computer to cross match. The old numbers are obsolete. But I believe Ford is still using these.
I bought these slides (1973/79 Ford LIGHT Truck Parts Catalog) from Ford last year. They are the last issue, as I stated above. I also have two earlier sets of slides, from 1978 and 1980. hipoparts.com sells a scanned CD version of this parts catalog. It was scanned from the 1979 issued paper catalog.
I can only tell you my experience, and the parts worked.
If Ford dealers did care, I woudn't have needed to type over 9500 posts in a single year here on FTE.
Sorry, no and I checked to see if I might still have the plastic bags they came in, but I don't. A tip here, the Ford dealer I went to is a small town dealer in Brooklyn, MI (Near Michigan International Speedway). I've found that the small town dealer parts departments are much more helpful than the big guys.
crazed87bronco
16
12-20-2014 01:37 PM
drof46
03-31-2009 07:57 PM
slckkw
11-16-2005 07:50 PM
