What size Tires and Rims is everyone running?
Old 11-07-2007, 10:28 AM
9teen56f100's Avatar
9teen56f100
9teen56f100 is offline
I'm running 255/60/15's on both ends.
brian...
Old 11-07-2007, 11:07 AM
joe hoffman's Avatar
joe hoffman
joe hoffman is offline
255x55x18, 8.5 Inch W/10mm Offset, Bfg Tires And Kmc Mags, All Four
Old 11-07-2007, 12:56 PM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
While it's true that they have big fenders I'd rather fill up a fender with a tire instead of a wheel. The 15 and 16 inch wheels make the truck look more traditional. I guess it depends on the look you are after...
Old 11-07-2007, 02:00 PM
doug51f1's Avatar
doug51f1
doug51f1 is offline
15x7's all the way around.
Old 11-07-2007, 02:13 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is offline
Roast em' if you got 'em
Received 3,778 Likes on 1,819 Posts
Originally Posted by Kecky
Hmmm, maybe it is true that you can tell a guys age by the size of his.... rims. Although I won't be putting 20's on my truck and I also don't like the "Rubber Band" tires, I do think our trucks look better with a 17" or bigger rim. The fenders are so big that a 15 or 16 inch rim seems to get lost in there. Also the thick sidewall tire looks "not right" to me. They make the rim look even smaller than 15 or 16 inches. Once again because of the large fenders.
I am planning on a 17 or 18" rim with a mid size sidewall... say a 45 - 55 profile.
Jut my opinion.
Kevin
LOL....I'd never heard that before but I can see how it might be a good generalization. Although I think I'm still a puppy, I'm 42 I like a more traditional look.
.......I have seen some larger wheels look great, and there's lots of great examples of it on this site. Like you said it all a matter of getting the proportions right. Still, to me, I like alot of rubber....lol
Bobby
Old 11-07-2007, 02:45 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
Talking
Jut my opinion.
Kevin
LOL, And a great opinion it is too.
Old 11-07-2007, 03:04 PM
ricksta56's Avatar
ricksta56
ricksta56 is offline
7.5x20
All 6 tires.
________________________
1951 Ford F5
1964 HD Sportster
Old 11-07-2007, 03:43 PM
merc546's Avatar
merc546
merc546 is offline
Hi
My 56 has a volarie frt susp (with dropped spindels) and a 70's era Ford truck 9 inch.
The front tires are P215/70R/15 and the rear tires are P235/70R15. B.F.Goodrich Silvertown Wide White Radials
The wheels are from "The Early Wheel Co" out of ca. The fronts are 15 x 7 with 4 inch back spacing and the rears are 15 x 8 with 4 1/2 inch back spacing.
Chuck
Old 11-07-2007, 04:37 PM
Quiff_boy_Elvis's Avatar
Quiff_boy_Elvis
Quiff_boy_Elvis is offline
my gallery has pic of my new torq thurst IIs and cobra radials
Cooper P225 70 R 15 front,
Cooper P235 70 R 15 rear
Old 11-07-2007, 04:55 PM
Jag Red 54's Avatar
Jag Red 54
Jag Red 54 is offline
I like the 15 x 8 rims with the big rubber lined up with the edge of the fenders. 15x8 rims reversed with 3" backspace with P275-60R. Also, by using the same size rim and tire all the way around, you can rotate the tires for better wear. Jag
Old 11-08-2007, 01:02 PM
ricksta56's Avatar
ricksta56
Every bit of info helps;
Checked my tires today, one had 5 psi, the other 5 had15-20 psi, pumped 'em all up to 42 psi for now, my book said 60-75 psi, depending on 7.5 or 8's. Them's 7.5X20 all 6. Also checked all the vehicles and had to make some adjustments there too. Now after lunch gotta get the gunk out of the bottom of the air tank.
Old 11-08-2007, 01:12 PM
doug51f1's Avatar
doug51f1
doug51f1 is offline
Glad you found a 56 you liked! Which one did you finally purchase? Is that the black one from England re painted red?
It looks great with that tire/wheel combo!
doug
  #28
Old 11-08-2007, 01:24 PM
Col Flashman's Avatar
Col Flashman
Col Flashman is offline
Originally Posted by F100man
Just wondering what size Tires and Rims everyone is running. I just finished up with the Mustang II install and was thinking about what it would look like and what rims and tires I will end up running. My truck will have a 3 degree rake with an 8.8 rearend. I guess I'll have to figure out the back spacing and such?
7.00x15 Tallboy's all the way around & she looks good wearing her Original MERCURY Truck Hubcaps!
  #29
Old 11-08-2007, 05:06 PM
52 Pickup's Avatar
52 Pickup
52 Pickup is offline
American Torq-thrust all around. 15X6 with 215/65 on the front and 15X8.5 with 255/60 on the rear of my 52 F1. Have 16X8 centerlines on my 69 short bed F100. 265/50 on the front and 295/50 on the rear. They were on the 69 when I bought it but am thinking about 60 series when I replace them.
  #30
Old 11-08-2007, 10:06 PM
rhopper's Avatar
rhopper
rhopper is offline
I setup my chassis on 15x7 wheels, junk tires, 235/70r15 front, 265/70r15 rear. Lots of sidewall, which is the look I want. Because I'm in the tire business, I probably won't pay for the good set, and I may go up one inch on the rim diameter for better gearing, and better selection.
Quick Reply: What size Tires and Rims is everyone running?
