You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
This weekend I competed in my first sled pull. Wasn't sure what to do, so I just put it to the floor. Got 35 swampers and Matt's agg race tune. Made my own hitch and traction bars. I still need to figure out how to start correctly so that my truck isn't hoppin so bad. The track was as hard as asphalt- may have had something to do with it. Anyways, it was awsome!
__________________
04 crew cab 6.0 4x4
train horns
SCT XCAL2 from Matt @ Spartan
remote start
5" lift with 35's
traction bars
4" MBRP turbo back straight piped to 6" single stack
some other pullin goodies
Should be in competition but I will leave it here...
Lift kits and pulling are not the best set up.....not sure what you have but the front end needs to stay low.
Locker up front
Clamp the rear springs, forward of the rear axle
Make a plate from the frame to the spring perch (both sides) with a 1 inch travel, play with the distance. This allows the rear springs to only compress 1 inch and locks the truck down. The sled becomes a good lever to put weight on your truck and the track.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
Do you ever read the magazine Diesel Power? Everybody has one stack.
__________________
04 crew cab 6.0 4x4
train horns
remote start
5" lift with 35's
traction bars
__________________
04 crew cab 6.0 4x4
train horns
remote start
5" lift with 35's
traction bars
single stacks are pretty cool. i'm eventually gonna get rid of my haulers in lew of a miter cut 8" single stack. nice job on spankin' the cummins!!!! pretty nice pull for just having the X-CAL2. throw some injectors in that mother and let 'er eat!!
The reason for the single stack rather than the double is that the double stack costs hp because you are spliting the air and making unwanted back pressure. Otherwise 2 actually looks better. JMO
FYI, a guy running a T (not a Y) on a 1000rwhp truck found 60 hp just taking the T out and running a single. Where else can you pick up 6% that easy? It would be less with a Y, but the concept is the same.
I saw that in a magazine. Also, if your blowing deep black smoke out of 2 you have to look at both to see the "HELL YA" results, with one its TONS MORE SMOKE AND AN EVEN BETTER "HELL YA"
__________________
1980 F-150 Custom : MILD 351M 4 speed granny low, 4x4 , 35 inch Regul Trailblazers, open headers.
1981 F-100 Custom : Stock 300-6
1995 Chevy C1500 2x4. 350TBI Headers, Cutouts and Flows. 18in rims 2 12's. DD and even better it gets 22mpg! BEST NEVER REST
