No way would I go over 4 inches......the slip yoke in the driveshaft would make that puppey fall right out with even minimal flex.....not too big of a price difference between the two but even when u did the 6 inch not only would you need the driveshafts..might need to change the pinion angle of the axle as well as extend the brake lines and possibly the steering shaft.....there are always other factors than just the obvious....Luck
