aiming headlights
http://www.analogstereo.com/pdf/om/f...anual_2005.pdf
See page 42. The procedure is different for the sealed beam headlights and the aerodynamic lights.
From the manual linked above:
AIMING THE HEADLAMPS
Your vehicle may be equipped with a sealed beam or aerodynamic
headlamp system. Sealed beam headlamps may be aimed in the vertical
(up/down) and the horizontal (left/right) directions using the procedures
following. The aerodynamic headlamps can only be aimed in the vertical
direction (up/down) using the following procedures. The headlamps on
your vehicle are properly aimed at the assembly plant and should not
normally need adjusting.
